Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cartridge jamb Pixma MP130
Always comes up cartridge jamb. Does not print. Tried many new cartridges. Nothing helps
I always go into the clean the printer and it works, usually. I have also tried the align printer head, it has worked at least once.
Posted on Oct 10, 2008
I cleaned the printer heads in the maitanence mode and it worked.
Posted on Nov 05, 2008
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130
1. Take out black and coloured ink cartridges.
2.Clean golden contacts with a q-tip dipped in alcohol'both on the print head and on the cartridge.
3. Dip the cartridge in a hot water bowl, let all the ink left flow out.
4. Wipe with a paper towel.
5. Let the parts dry out for at least 24 hours
Oct 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My mp130 does not print and says put in cartridge
call a technical support to fix your printer... its a mechanical or board problem inside...
Jun 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
May 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Cartridge jammed
my canon pixma mp 130 says it has a cartridge jammed...Ive tried new cartridges but still get the same situation
Aug 17, 2008 | Office Equipment & Supplies
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
My printer says "cartridge jammed" and wont print! HELP!
Have you removed and replaced the cart with a new one? If that hasn't fixed it, you may be looking at goo in the cartridge area. You can often use a swab (Q Tip) soaked in alcohol to clean this up.
Jan 05, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
