Question about GE Dishwashers
Dishwasher model c5420 won't drain. Checked drain hose and air gap, both are clean.
  • 639 Answers
Dear friend,
ngfam at you service! happy to assist!
Sounds like a pump problem !
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
How do unclog the drain on my dishwasher model 665.16902400
Unhook the drain hose for the sink connection. Clean out port connection of the sink connection..
leave the hos off until you complete Air-Gap inspecion / cleaning (next)
On most installs there is an Air-Gap on the back of the kitchen sink.
images?q=tbn:and9gcq21cbh2axzfji-fvyvbg8mgnyhpmkowhj1toxxffd2qewqkya7dbgxkvqy
Pull the outer shell cover straight up and off.
NOTE the inner nut and diverter cap installed position. (It only fits one way)
Unscrew the inner plastic nut
Remove diverter cap.
Use a flash light and wire coat hanger to clear any obstructions from the outlet. Place the end you removed from thge cink connection into a bucket and pour water into the hole where the diverter cap was. This will flush the drain portion of the Air-gap and outlet hole to the sink connection.
Next remove the dishwasher drain hose from the air gap connection. Place removed Hose in the bucket and secure it if you can not hold it.
Set diswasher to wash or cancel drain and let the residual water in the dishwasher pump into the bucket. (can make a mess if pump flow is strong.) Keep a rag in your hand. If you now have good flow... reconnect the dishwasher drain hose to the Air-Gap Connection and the Air Gap to sink connection to the sink connecton port. Task complete.
If you still have a problem after doing the above... Remove the drain hose from the dishwasher connection and check the dishwasher outlet port for obstructions. Remove any obstructions.
Ok now... if it is still not draining.. I need to confirm your model number because it is not crossing to any repair or parts data. You posted 665.16902400 is this correct? Let me know if your stil having problems. I think I can work around the model number issue but would prefer to have a good model number if you have to remove the lower wash arm and clean the sump area. (Last)
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Dishwashers
Water in bottom will not drain, checked air vent..., it;s clear
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Sep 19, 2009 | GE Dishwashers
My frigidaire dishwasher routinely leaves some water in the bottom after it is finished washing and the dishes are always wet on the top
2. Broken belt
3. Pump
Jul 19, 2009 | Dishwashers
Dishwasher not draining water
I had the same problem....removed hoses, checked for cloggs the hole nine yards.....Inside of the unit towards the back in the bottom is a filter cover and in the middle is a valve that you just screw out. It has a rubber stopper that overtime breaks down....I was able to pick up the part locally for about $17CDN, replaced the part and the unit drains properly now.....now I have an issue with no power
Jun 25, 2009 | GE Dishwashers
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 03, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher stops after 10 minutes inlet/drain light flashing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Water not completely draining... hose not clogged.
Check all the above to address thsi issue.
Apr 15, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Does not drain. Water stays in the bottom.
Apr 13, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher dosen't drain completely
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
66 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
