Question about Sony MHC-GX450 CD Shelf System
The sound is too low
My system's sound can only be heard a little bit when volume is at max. Whenever I turn it off for a while and turn back on it works normally for a few seconds then the sound goes out again
I have the same thing...did u ever find a solution?
Posted on May 26, 2010
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
When I connect me ipad to the Philips mx5500D the sound is low
maybe your ipad's volume is low - volume settings for ipads are different when both plugged / unplugged
Oct 27, 2012 | Philips MX5500D System
How do i repair low audio on my philips soundbar hts8100/37. All connections are correct. I have to turn sound bar up to max volume to hear it. The problem is intermittent. Could it be a software problem.
My HTS8100 2 yrs ago stopped working properly, sound was on its max and little was heard. Well after searching for solutions and took it for repair which was a waste, my brother came from Australia for a holiday who is a technician and fixed it for me. The problem is in the subwoofer, I am uploading a photo where this part is , STRX6759 SANKEN INTEGRATED CIRCUIT STRX6759. Its behind that capasitor. When I changed it the sound worked. Hope you will find it useful.
Feb 01, 2011 | Philips SoundBar DVD Home Theater with...
Philips HTS8100 owner. Have ben using the soundbar since Decembr 2007 with no issues. it is intgrated with a sony bravia tv. tried to turn on sound (tv input) and have very limited sound. Turned up to...
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Dec 22, 2010 | Philips SoundBar DVD Home Theater with...
The amp keep cliping out whenever i turn the volume up..when the volume is turned down low its place find..
Make sure you power wire and ground wire are at least 1/0. That is a heavy power amp and must have all the amps it can have...if you are wired good, you may need to reduce your gain a little bit.
Mar 29, 2010 | Concept 3900 Watt Class-D Mono-Block...
No sound when radio is turned on
i have the same problem with mine..did u ever find out how to fix it?
Jun 04, 2009 | Sony MHC-GX450 CD Shelf System
Low volume on the dvd player
hi, guys, you are controlling the windows settings for the sound card, thats ok, but u need to chech if the DVD sound settings are set to surround 5.1 channel, now where the settings are will depend on what player u are using. let me know guys??
Dec 31, 2007 | Acer Aspire 3610 Notebook
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Sony MHC-GX450 CD Shelf System Logo
99 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
