Question about Brother MFC 9600 All-In-One Laser Printer
Manual where can I find an online manual for the Brother MFC 9600?
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
MFC 9600
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 29, 2008
Change baud rate on brother fax machine
Lowering the Baud rate on Brother fax machines.
  • Press the Menu or Menu/Set key. Then Fax, Miscellaneous and Compatibility.
  • Press the Up or Down key until you can select Basic. Basic reduces the modem speed to 9600 bps.
  • Press OK or Menu/Set or Set key.
  • Press Stop/Exit.
Note these instructions should work for the following models: Fax-1835C, Fax-1840C, Fax-1940CN, Fax-2440C, Fax-2820, Fax-2825, Fax-2920, MFC-210C, MFC-215C, MFC-240C, MFC-3240C, MFC-3340c, and most other MFC models.
http://www.voipmechanic.com/voip-fax-settings-9600-baud.htm
Mar 06, 2012 | Brother FAX-8360P Plain Paper Laser
Change baud rate for brother fax
  • Press Stop/Exit.
Where is the printer paper tray on Brother MFC 9600
Most of the time it's located on the bottom of the printer. If it's the same as your picture, just grab where it arches up and pull outward and the paper tray should come out.
Jun 15, 2011 | Brother MFC 9600 All-In-One Laser Printer
How do I print in color & can I download the software off the internet with the brother mfc 9600 all in one
This printer only prints black. Down load drivers from brother.com Thank you, Steven 805-520-3003
Jul 08, 2010 | Brother MFC 9600 All-In-One Laser Printer
Laser MFC 9600 IS PRINTING BLACK LINES ON COPIES
Take out the drum and toner and slide the tab on the top right cover 15 times. Also clean the two Scanner glass windows under the cover.
Jan 06, 2010 | Brother MFC 9600 All-In-One Laser Printer
How to change fax speed from14.4 to 9600
The machine does this automatically on connection. It negotiates a reliable connection speed with the recipient machine and then transmits data. If in encounters an error repeatedly it will negotiate the speed down even further until the data can be sent successfully. However the following menu setup option may help
Main MenuFaxSetup SendOverseas ModeOn will change the speed down to 9600 max and negotiate downwards if required.
Oct 30, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc 9600 error 78
Try turning the machine on and then off - you may have to unplug it
Mar 11, 2009 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 won't pull paper from tray
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Brother MFC 9600 All-In-One Laser Printer
Need User Manual for Brother MFC 9600 All In One
Here's the link; http://www.amazon.com/Brother-MFC9600-Flatbed-Laser-Multifunction/dp/B00004U4A0 Under "product details". Hope this helps :)
Sep 11, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
114 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
