Question about Hitachi 42HDS69 42 in. Plasma Television
Loud noises My Hitachi 42HDS69 is having audio problems. The sound is all the way off and it is making a loud scramble/garbled noise. If I hit mute on the remote it changes to a higher pitch tone. Any idea why?
  • elfis01 Aug 31, 2008
    Thanks for the advice, it worked like a charm. Any idea why it would do that? My wife said she just turned it on and the sound was garbled.
  • elfis01 Sep 02, 2008
    Thanks again for your solution and your time. :)
  • 71 Answers
Try resetting the TV. Unplug the AC, wait 1 minute then replug it. If not fixed, its requires service.
Posted on Aug 29, 2008
  • Ignatz Saturation Sep 02, 2008
    All LCD TVs are like little computers, but no keyboard and no reset button. When it goes awry the only it needs to be rebooted, but there is no single switch to do that.
    Most all LCD TV problems that are 'wierd' can be fixed the same way, unplug and reboot to 'erase' the memory.
    However, the same problem may reappear since there is either a bug in the program, called firmware, or there is a defect in the hardware that can show up when the unit is run for some time, hopefully the same solution will work.
Hitachi LCD TV lost sound without any warning. Was working fine and paused live TV on the Sky box. When we took off pause no sound at all. No crackling speakers or anything at any time prior to this or...
Try to check first the audio setting in the main menu, to make sure that the speaker are not set off or the mute setting. and you can use a multi media speaker or computer speaker and install it at the audio output of your tv to be sure that you are getting sounds, if you are getting sounds then the problem can be in the power amp circuit, but if you do not get any sounds the problem would be the sound processor circuit you may need to bring it in the repair shop or you can contact a service technician to repair it for you and save you from stress good day and best regards.
Aug 28, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Intermitten problem with hitachi plasma on power up
well aparently all you do is fish for customers to buy into your sevice!
I DIDNT GET ANY HELP FROM YOU GUYS, TAKE YOUR "FREE" TECH SUPPORT AND SHOVE IT UP YOUR ***!!!!!!!
Nov 12, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Using s video from laptop to tv, audio connection does nothing no matter which input I try - how do I get audio to the 42hds69?
I don't know which laptop you have, but I've connected plenty of computers to plenty of TVs, & I can tell you there is no audio signal on an s-video connection. Right now I use a digital SPDIF output on my computer that runs to my AV receiver for sound. This uses a regular RCA-type cable to send dolby multichannel sound to my amp. If you don't have a digital-out for audio on your laptop, the next solution is a cable which has on one end a 3.5mm mini-jack (headphone plug) and on the other end has two RCA-type connectors. These are very common cables available anywhere cables are sold. Buy a short one and then use couplers and a longer cord to reach all the way to your TV or amp.
Sep 19, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
No sound on one channel
check your remote for a a audio button alot of times certain channels like PBS only plays in one sound It will be the button that changes the Mono/Sap/Main settings for audio or it could be a issue that network is having
Apr 28, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Compaq armada m700 making loud noises
Could be hard drive, bad speakers, or even a bad sound chip on the motherboard. what kind of noise exactly is it??
Does it make the noise while playing music or anything else??
Dec 23, 2007 | Compaq Armada M700 Notebook
Hitachi 42HDS69 42 in. Plasma Television Logo
284 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
