Question about Toshiba Satellite A105-S4334 Notebook
Turned on and smoke
Smoke came from the bottom . i took the cover off and part off the circuit was burnt . is the mother board destroyed ?
    Genius:
  • 2,028 Answers
Is the burnt circuit on the motherboard or the power switch circuit board that plugs into the motherboard? Big difference, if the burnt circuit is on the motherboard then yes the motherboard is done and will have to be replaced, but if it's just the power switch circuit bard, then this is replaceable.
Posted on Aug 28, 2008
Why did my 1984 chevy 305 start blowing white smoke so i checked oil and found water in it. but as i took off valve covers i found metal peices
White smoke, coolant in the oil-you had a cylinder head gasket failure. The valve train pieces indicate more damage-whew! Hard to guess, but if the coolant was in the oil for some time, it may have destroyed the engine. The bottom end bearings could be shot as well. I would be looking for a replacement low mileage engine. Or buy a NEW CAR!
May 03, 2014 | 1985 Chevrolet Chevy
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
No lights. dead. checked plug
Unplug the brewer. Turn it upside down. You may need to use a small screwdriver to remove small rubber pads that cover screws that hold the bottom cover to the brewer body. Remove those screws. Using a volt-ohm meter, check to see if you have power coming from the power cord to the brewer at the points on the circuit board. IF NOT, REPLACE THE POWER CORD ( cheap fix). If the power cord is working, when you take off the bottom cover and you will find a small circuit board that has very small switches that actuate the brewer. Take that circuit board off, and with a toothbrush and water/soap solution, gently clean the circuit board and then let it dry completely. CHECK the board to see if their are any burnt areas, or any deposits that are corroding connections, and check to see if all connections are unbroken. Fix anything with a small soldering iron that has separated. Let the circuit board dry in the sunlight, and then replace it and the wires connected to it. Try then to plug the cord in and turn the brewer on to see if the lights work then. IF NOT, you will have to replace the circuit board.
Sep 20, 2012 | Keurig B40 Single-Cup Brewer
I have a cobra CB. I went to hook it up today, and the fuse popped. I went to unhook it and noticed that the radio was smoking. I took the cover off to take a look and see if everything was OK. There is...
Most CB radio have a diode near the B+ leads going in the circuit board, by your description when you hooked it up you probably got the + and - mixed up and put them in reverse by mistake, when this happens it will short out the diode and sometimes destroy the audio output ic and open a trace on the circuit board before it blows the fuse as it smokes. The diode must be replaced and burnt spot repaired on the circuit board, if you are very lucky the audio ic will come out unharmed.
Mar 02, 2011 | Cobra 19 DX IV CB Radio
I have a studio laptop.it was destroyed(burnt) during lightnenning.it's not working now.should the entire mother board be changed?or is it just the card?what will be the approximate charge?
The Entire motherboard should be changed. The Ethernet card is directly on the board and if it is burnt, it will affect the motherboard. You may need to change the entire board.
Nov 23, 2010 | Dell Ethernet Card Network Adapter
Dd603 info only acrid smell/smoke from upper
INFO ONLY- POTENTIAL FLUIDS CONTAMINATING CIRCUIT BOARD
EDGE CONNECTORS
Jan 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Does it have a fuse we got hit by lighting and now the Pc wont power up
To fix the problem, you need to disassemble the power supply, replace the burnt out fuse, & also check the bridge rectifier section for burnt out rectifying diodes (these usually get burnt out if the high current gets the chance to leak past the fuse, which could sometimes happen). If you find burnt out rectifying diodes, you will need to replace them as well, as they could burn out the fuse again when you try to use the power supply while they are still there.
Dec 20, 2009 | Codegen : 350W ATX Power Supply With 12cm...
Burnt out power board
I sympathize with your problem, but I think you are knocking at the wrong door. You should contact your local Packard Bell dealer.
Hope it helps
Aug 28, 2009 | Computers & Internet
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
Toshiba Satellite A105-S4334 Notebook Logo
123 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
