Question about Directv D11 DTV Receiver
Password my wife put parental lock on for our kids and now don't remember what the code is to unlock it. I stayed on hold for 30 minutes with direct tv i guess they are busy is there anyway to bypass code on this reciever or am i just going to stay on hold forever. Thanks alot
  • ladywinn
    ladywinn Sep 08, 2008
    I have the same problem someone enter a password on ratings and now i am unable to watch alot of channels that i am paying for,need to know how to unlock!
  • dbralley Nov 28, 2008
    forgot my passcode how do i get it?
  • 5,138 Answers
Directv says the only way to UNLOCK PASSWORD is to call them give them your account .box ID and ascess ID.They will unlock box by satillite signal .
Posted on Sep 11, 2008
    Problem Solver:
  • 8 Answers
If you go into your system setup menu, it should give you a 'reset' option that will reset EVERYTHING and take you back through the guided setup (best advice to get through that is just keep selecting continue, even if it gives you an error message on your satellite signal screen). It will reset your passwords and give you back control of your receiver.
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Samsung UA60D6600 60in. LED TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Parental code not working on sansui television
Instructions
Jun 27, 2012 | Sansui Televison & Video
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
PARENTAL LOCK?
are you the parent or the kid if your the kid none of use are going to bea ble to help thats between you and your parents if you are the parent then...ther really is no way to get rid of it with out the password
Jan 08, 2009 | RCA F27625 27" TV
PASSWORD OVERWRITE CODE
If you forgot your password, simultaneously press and hold MENU on the television and volume down on the remote for 3 seconds. Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls
Apr 02, 2008 | RCA F27628 27" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
New - parental lock LOCKED and password will nowr work can't use DVD
Problems with V-Chip/Parental Controls
The rating limits don’t work
• For rating limits to take effect, you must lock V-Chip settings to activate them.
I don’t remember my password and I want to unlock the TV
• If you forget your password you can reset it. Enter 5898 as the password and then change it
to a new one.
Dec 06, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Directv D11 DTV Receiver Logo
1,042 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
