Question about Black & Decker String Trimmer Cordless 12" 18V
Cordles 12 vold Trimmer
Need parts
Batery Charger
Cap for botem of spool
  • uitanw Mar 07, 2009
    Thank you for trying I will by a new one do not send me any more
    advertising thank you
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
Posted on Jul 14, 2008
vincob
  • 718 Answers
SOURCE: I have a Black & Decker 12v, 12" cordless
Do a random Google search for your model and maybe even serial number and you will find what you are looking for.
Posted on Aug 30, 2010
riceski
  • 1851 Answers
SOURCE: I am tryinng to remove
These are REVERSE THREAD - this should do it - turn it the other way.
Gary @ Fix Ya
Posted on Sep 05, 2010
  • 5370 Answers
SOURCE: I have taken the orange
  • Turn trimmer upside down,make sure bottom is clean, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool.Push in on the tabs of the spool retaining ring to lift the ring off the trimmer.Pull the old spool off of the shaft, and dispose of it in a waste receptacle.-------
    To reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup .Also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.Put on cap, on the auto feed the line comes out when you turn trimmer on,--------------
    Click the link below for image of the spool and trimmer/edger :---
    http://www.ereplacementparts.com/black-and-decker-gh700-grasshog-trimmeredger-parts-c-4167_9518_9530.html
    This should help.Thanks.Helpmech.
  • Posted on Apr 12, 2011
    Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
    How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
    If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
    Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
    I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
    Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
    If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
    Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
    Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
    Sep 01, 2013 | Weedeater Garden
    I have a Black & Decker 12v, 12" cordless trimmer (CST2000). The charger is missing. Can I buy a replacement? Is there a part number?
    Aug 30, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
    Have a cst2000 but do not have the charger
    The charger for the CST2000 is part #243248-00, but it is obsolete now. You could maybe find a used one for sale on eBay or craigslist, though.
    Apr 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
    Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
    Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
    Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
    I need part for a Craftsman Weedwacker
    You can either go to sears, or craftsman website or even easier if you can get one off of ebay
    Aug 18, 2009 | Garden
    Broken spool cap
    I would say yes, here is a site for parts, if this is not helpful please specify your model number
    http://www.toolpartsdirect.com/blackdecker/blackdecker-41.html
    also here is the actual black and decker parts site.
    http://www.blackanddecker.com/CustomerCenter/Parts.aspx
    Jun 01, 2009 | Black & Decker String Trimmer Cordless 12"...
    How do I insert sring into trimmer
    1. take spool cap off;
    2. take your spool out of spool housing;
    3. reload line on the groove of your spool;
    4. final, get it back.
    Aug 04, 2008 | Black & Decker String Trimmer Cordless 12"...
    My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
    check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
    thanx
    Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
    Black & Decker String Trimmer Cordless 12" 18V Logo
    Top Black & Decker Garden Experts
    Jim Parker
    Jim Parker
    Nick Olsen
    Simon Elder
    Level 1 Expert
    Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
