Question about Philips Magnavox 9P6034C 60" Rear Projection Television
60" TV has an arc in the pic
The top and bottom of the picture bow in to the center a few inches. I put a new chip in for picture shrinking , thats fixed.
  • Anonymous Oct 15, 2008
    yes i do what is the chip kit part needed to fix it thanks
  • cherokee52 Oct 15, 2008
    whats the chip kit no. thanks
  • Philips Master
  • 3,459 Answers
Check the fuses 1007 & 1405. If they are blown in will cause an Arc.
Note: If the screen shrinks/expands you may need a chip kit from www.repairkits.com
Posted on Oct 12, 2008
  • Edward
    Edward Oct 18, 2008
    Sorrry - I typed the url in wrong.  The fix is avail at www.TvRepairKits.com.
    Good luck
  • Edward
    Edward Jan 11, 2009
    If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
    Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
    Symptom: No Audio or Video but power light is on
    Symptom: Audio works but no Video. Power light still work
    Symptom: No Video. Audio is intermittent. Power light still works
    President:
  • 3,130 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your TV most likely has one of two possible problems. Problem #1: Convergence Chip Failure ( common problem ) Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped. Here is a quick test.... Using your original remote go-to the tv settings then goto the convergence section. Try to adjust the red and then the blue convergence. You should be able to move them up, down, left, and right. If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1 You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for most models. If you don't see kits for your set send them a quick note
Posted on Sep 01, 2009
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
9p5544c102 Horizontal bow
ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
