Can't hook up my router. i hook up the router but cant remember how to set it up to pick up the ip address' I have a Blitzz netwave base g4 wireless router. how do i connect to the internet?
    Brigadier General:
  • 5,158 Answers
Open your internet explorer and type in 192.168.1.254
it should ask you for your password
the settings are in there.
set it up according to which internet service you have be it dsl cable etc.
there should be some instructions in that page when you get to the setup page.
Robert
Posted on Aug 28, 2008
I am unable to access my blitzz bwp611 router. I have tried 192.168.1.254 and 192.168.0.1 to no avail. How can I gain access to this router?
The router should be accessible from the Default Gateway IP Address of your network. Examples I have found are like this:
http://portforward.com/english/routers/port_forwarding/Blitzz/BWA611/Command_and_Conquer_Red_Alert_Counterstrike.htm
you can check you default gateway by opening a command window (Start CMD, right click CMD on the Menu for Vista/7, Start, run cmd for XP) on the command line type IPCONFIG
This will give you your IP address, Subnet Mask and Default Gateway IP address. Type the Default Gateway IP address in to you address line of the browser, you should get a sign in prompt. Unless you changed the default settings, the username and password should be left blank. That should give you access.
Jul 10, 2011 | Blitzz Technology (BWP712) 802.11g/b...
How can I secure my network with one main computer and two wireless devices? I have a Blitzz Netwave Base II On a dsl modem. Thanks
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 09, 2009 | Blitzz Technology (BWA611) Router
Will Blitzz BWA 711 reset button clear the password/login, too?
Yes - the reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address of 192.168.1.1
The default username and password for your Blitzz BWA711 router are both "admin".
Don't forget that all your personal settings will be erased as well (wireless security, port forwarding etc.)
This is what I did after entering all that information again:
I went to each screen and took a snapshot of that window (Press ALT+PrintScreen). This screenshot I copied into a Word document and repeated these steps with all important windows. Now I have a little "manual" in case I have to reset my router again and can't remember my "fancy" settings.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 28, 2009 | Blitzz Technology BWA711 (B3WL000900)...
I have a Netwave Base G4 wireless router w/ 4- port switch,trying to network two computers via cable modem using local ports,modem and router not communicating
You need to change the LAN IP address of your router. Open the router's admin through http://192.168.1.1 and look for router's IP address or Local IP Address. Change it to 192.168.10.1 and save the settings. Reboot the router after that. If you are on cable internet , you need to do MAC Cloning. Access the router's admin page and look for MAC Clone settings. Enable and clone the PC's Mac Address. Save the settings and power cycle the router and the modem after that.
Aug 02, 2009 | Blitzz Technology (BWA611) Router
Don't have manual or cd
This will show you how to get into the router. Even though these are the steps for port fowarding. You should still be able to set up your router with these instructions:
http://www.portforward.com/english/routers/port_forwarding/Blitzz/BWA611/eJamming_Station.htm
Jun 27, 2009 | Blitzz Technology (BWA611) Router
Router W/o cd or manual how to get to work with pc.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.254. Then hit "ENTER".
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are blank. Click the Ok button to log in to your router. That should get you in, but if you get kicked out, because of wrong username or password. On the back of the router should have reset switch or button in a small hole. Press and hold that for about a minute. Should reset to factory default. Sorry forgot to say that you will need to use a paper clip to fit into reset switch. The big paper clip is the best and it needs to be straighten a little.
Jun 02, 2009 | Blitzz Technology (BWA611) Router
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Router
go to your "connect to" icon in the start menu, click"setup new connection" go through the steps when it asks you for encryption type click something other than "open" and enter your desired passcode
Apr 27, 2008 | Blitzz Technology (BWA611) Router
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
