Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Stopped working while vacuuming heavy dust on patio the vacuum suddenly stopped working. I tried it on other outlets with no luck. I cleaned the filters and still no luck. Is there a circuit breaker if it get hot?
  • lguthery Sep 23, 2008
    My DC 14 just quit working, has been siiting for a few months and still does not turn on.
  • Anonymous Nov 27, 2008
    While using the vac it shuts down and has too cool every time I use it
It cooled down and worked 20 minutes later
Posted on Aug 29, 2008
I have Ridgid wet/dry shop vac, I was vacuuming
Did you have a paper/cardboard filter attached to the top part of the unit? Sounds like you didn't have a filter or the silicate material got past it and into the motor and windings. Bad news if this is the case. Try taking the top part off, turn it on to see if it runs without the bottom tank section. Double check to see if your vac has a fuze. If it won't go on you'll need to dismantle the upper unit and clean it all out. Hand turn the motor and see if it easily turns or is sluggish. My wife used my wet/dry vac without the filter and wrecked it with sheetrock dust into the motor. I dismantled the top, cleaned it twice and it's still no good. By the way, generally you have to take the paper filter out if you are vacuuming wet up. If you leave the paper filter on and vacuum wet up, the paper filter will get wet, shred and get pulled into the upper motor unit. A wet/dry vac isn't really made to pump water (by the gallons) out of places, so don't expect that. Okay yes you can often hook up an outlet hose to the drain port at the back of the tank and vacuum quantities of water, but it's not really made to do this.
Aug 28, 2014 | Vacuums
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
My dyson no longer will turn on. Is there some filters I am supposed to be cleaning. Purchased the vacuum from someone who did not have the manual.
you have two filters, one under the lid on your dust bin and one in the ball. It could be the switch has gone bad because of overheating.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 12, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
I was vacuuming with my Hoover Windtunnel Rewind t-series, and the vacuum simply stopped working. I plugged it into other outlets all around the house but no power suddenly.
Wait 30 minutes and try again, there is a thermal overload switch that resets itself.
Clean all three filters and see what happens.
Gary
Feb 23, 2011 | Hoover Vacuums
I HAVE A MODEL C104A ELECTROLUX RENAISSANCE AND IT JUST STOPS WHILE YOU ARE VACUUMING BUT IF YOU PRESS THE START BUTTON IT WILL START WORKING. I NEED TO KNOW WHY IT JUST TURNS-OFF?
There's a very good chance that it's overheating.?
Have you made sure that ALL of the filters are clean.?
If you've ever vacuumed-up anything damp or wet, it will then begin to attract dust to the damp parts & then dry the dust out, forming a skin.
A good clean of the filters & pipes (especially at joints & bends might fix it.
As Aerus Guy says, go to the manufacturers website & see if they have a troubleshooting/fault finding guide to help you.?
Best of luck.
Dec 22, 2010 | Electrolux C101 Bagged Canister Vacuum
Stopped suddenly, won't start back
Your vacuum has an auto shut off when motor gets hot. It comes back on after 1 hour & is cooled down. While it is cooling down, you want to check the following; look for either a blockage in either the main hose, or lower hose, or just need to clean the dust cup foam & filter, & check the hepa filter on the side of the vacuum.
Sep 05, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Stopped working suddenly. wont come back on.
try another otlet.if you have it plugged into a gfi outlet the little circit beraker on the outlet might have trippid if so push in on the red buttom till you hear it ckick.thatd resetting the gfi outlet.those kind of outlets can be found in thr kitchen,bathroom and outside.
Apr 16, 2009 | Oreck XLS700A Upright Vacuum
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
679 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
