Question about GE Kitchen Ranges
I've had a GE JGSP28 stove for about a year with no problems. Today I came home after my cleaning service had cleaned the house and found that the burners were making the clicking noise every few seconds like they were trying to ignite, even though all the knobs are set to the off position. Any suggestions?
  • 1,543 Answers
Water or cleaning solution may have gotten into a switch, or a switch may have gotten broken and is not lined up correctly anymore. There is a switch behind each of the burner knobs.
Posted on Aug 28, 2008
I have a 30 year old GE electric 2oven range One is up where you would think a microwave would be today. need to replace the element on the lower self cleaning oven. Where can I buy an element?
most electrical wholesale shops carry elements for stoves
the ranges may change but the elements stay fairly constant
if it is possible take the old element with you for comparison
Oct 20, 2015 | GE Kitchen Ranges
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Jul 26, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
During cleaning process, blew house breaker. Reset
Seems like you found out the hard way what I wrote about in this tip...
Yuor wiring has been incinerated with the stuff in your oven...
Yes, it can be fixed, depending on what and how much has burnt...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 23, 2010 | Kenmore Ovens
Are replacement decals available for the heat settings around the stove knobs?
I Just called GE about this problem, wanna know their answer???
Replace the whole stainless stell cook top piece for $325 ! ! !
Customer Service, at its finest.
This is obviously a GE problem , i live in a neighborhood of recently constructed homes, all of which have the same GE appliances, and all my neighbors are having the same issues.
Gee, thanks GE
Aug 14, 2010 | GE 30 in.JGP330 Gas Cooktop
GE stove JGSP28 igniter has been clicking non-stop for the last 2weeks. Blow drying the burners has slowed down the clicking to every 5sec. Front two burners seem to be clicking at the same time while...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter.
A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you make need to replace the electric igniter module. Good luck.
Jul 16, 2010 | GE JGSP28SEKSS Stainless Steel Gas Kitchen...
Hi. Stupid question for you, but I just can't find my manual! The model # of my GE self cleaning range is GRCR3630ZWW-2 if this helps. I need to clean my range today and how exactly do I do that using...
Hi, check this web page, which is a PDF file of GE oven manuals. It appears that you have to close a latch on the door to start the self cleaning.
http://www.abt.com/images/products/BDP%20images/ge_jbp24_man.pdf
Hope this helps!
Apr 25, 2010 | GE JBP68 CleanDesign Electric Kitchen...
GE JGSP28 Range broiler problem: flame comes out when door opened
The air shutter should be completely open. A possible adjustment may be necessary towards the closed position. The orifice needle at the orifice hood may be too tight. Take a 1/2 inch open end wrench and turn the hood counterclockwise to reduce pressure on the needle. Do this with the air shutter completely open. Your flame should reduce in size. The best flame would be about 1 inch long with white tips.
Make the adjustments with the flame off. Then light it and check it. If more adjustment is necessary,turn the broiler off before adjusting.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
How to clean?
The best cleaner I've found was from my Oreck store. It's called Stone Countertop Cleaner. It works!! It might leave a little glaze but after I spray, let set for a couple a minutes and wipe off, then go back over it with a clean paper towel after it dries, it looks as good as new.
Jun 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
312 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
