Question about Microsoft LifeCam VX-3000 Web Camera
Webcam- Microsoft- VX3000
I record the video and when I play it back, I hear this high pitch while listening to the video. I tried adjusting volume controls etc, but nothing is working. can you help plz, thanks
  • Ravel Lively
    Ravel Lively May 11, 2010
    Is it possible that your microphone is to close to your speakers forcing feedback into the recording?
I want to instal the VX-3000 web cam Driver into my laptop.
Posted on Sep 06, 2008
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
Since installing Microsoft Lifecam VX3000, I have no sound on my computer or on the Lifecam
check your audio out
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 06, 2010 | Microsoft LifeCam VX-3000 Web Camera
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
I can see and hear my contact but they cannot hear me I have tested all the audio and microphone tests and they check out fine
MIC SET-UP :- VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | Microsoft LifeCam VX-3000 Web Camera
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Cant get mic to work on webcam vx3000
check that pc sound proteries are set to usb camera and not your computers own sound card . can be check via properties on speaker in task bar. Right click speaker and sellect adjust audio properties and make sure usb camera is selected for voice recording.
Sep 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
Audio on Webcam is distorted - seems to be recording at a slower speed and palying back at normal spped
as a workaround you can use the headset, you just need to configure your messenger again to use the sound from the mic input instead from the webcam.
May 28, 2008 | Logitech QuickCam Pro 5000 Webcam
RECORD VOULUME
put the camera into manual mode from there get into the menu options and adjust the recording volume level.
May 18, 2008 | JVC GR D370US camcorder Mini DV
Microsoft VX3000
I NEED A FREE DRIVER MICROSOFT WEB CAM VX-300
WHERE ARE I WILL GET?
Oct 21, 2007 | Microsoft LifeCam VX-3000 Web Camera
Microsoft LifeCam VX-3000 Web Camera Logo
116 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
