My laptop comes with disk read error. I have tried the recovery disk but it fails on find disk.sys
  • Roberta Smith
    Roberta Smith May 11, 2010
    is the recovery disk clean without any scratches ?
    Robert
  • 95 Answers
Is this a new laptop?
Posted on Aug 29, 2008
BSOD constantly comes up on Dell Latitude D600 with several different error messages. Is this common with this laptop?
On the dell screen press f12 run the diagnostic option if anything fails replace that part. If nothing fails try system restore or just reload the computer with the operating system disk
Feb 18, 2012 | Dell Latitude D600 Notebook
I have a dell inspiron 8500. Occasionally it would go through post and come up with disk read error press ctrl alt del to restart then it came up with the ntfs.sys file was missing. I manually reinstalled...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 12, 2011 | Dell Inspiron 8500 Notebook
Error Code: Oxdooooo1e
this is a memory fail...and it is usually caused by errors on the disk or ram memory ...try to not use the recovery disk .and instead use a clean windows and boot until you have the choice to delete the partitions and format again from scratch..
after that install to the end and use the recovery cd just for the drivers ...
Jan 28, 2010 | Acer Aspire 3680 Laptop
I have a system32\drivers\Ntfs.sys error. wat can
Use the information provided by Microsoft to help resolve this problem:
http://support.microsoft.com/kb/555531
If this does not work try to run CHKDSK /R from command prompt. You can do this with Windows Recovery Disk.
Dec 02, 2009 | E-Machines M5310 PC Notebook
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
Blue screen error 0x00000024 dont have recovery disk
This Stop message, also known as Stop 0x24, indicates that a problem occurred within Ntfs.sys (the driver file that allows the system to read and write to NTFS drives).
Resolving the ProblemDisk Corruption. Corruption in the NTFS file system or bad blocks (sectors) on the hard disk can induce this error. Corrupted SCSI and EIDE drivers can also adversely affect the systems ability to read and write to disk, thus causing the error.
Check Event Viewer for error messages from SCSI and FASTFAT (System Log) or Autochk (Application Log) that might help pinpoint the device or driver that is causing the error. Try disabling any virus scanners, backup programs, or disk defragmenter tools that continually monitor the system. You also need to run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Run Chkdsk /f /r to detect and resolve any file system structural corruption. You must restart the system before the disk scan begins on a system partition. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r.
rate me if you think its fixya...
regards,
Dec 06, 2008 | Gateway MX6025 Notebook Computer...
Presario 1700T wont boot- missing "system32\drivers\pci.sys".
you may want to try booting up from xp or recovery disk and select "R" to repair.
Jul 07, 2008 | HP Compaq Presario 1700T Notebook
Acer 5570z laptop ql2200.sys error
Clean the recovery CD if you are using one.
If the recovery runs from the hard drive you may have a failing hard drive.
You can download an image of a CD (an ISO file) from
http://www.hitachigst.com/hdd/support/download.htm
If you dont have software or are unsure how to burn an ISO image get this:
http://isorecorder.alexfeinman.com/isorecorder.htm
Dec 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
David Payne
David Payne
