Washing Machines Logo
A
Anonymous Posted on Jul 20, 2011
Washing machine WD14700RD has stopped and is displaying an 'E' missing the top horizontal line, followed by another 'E'. It beeps even when the power is off
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Jul 20, 2011
Anonymous
Expert
Level 2:
Answers
489
Questions
0
Helped
299218
Points
854
The error code is tE. You have a thermistor problem and needs to be addressed by an LG technician.
Hi there - fisher and paykel washing machine is not spinning/draining properly - it starts draining but once the spin is engaged it slows donw, stops and starts beeping - thanks guys
More info needed. What is the model number? Is it a top or front load machine? What is the error code displayed when it beeps? If it is a top load machine then while it is beeping take note of which lights are on and which are off along the top row of 8 lights. Count from left to right and note the number of the lights that are on.
2answers
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
1helpful
2answers
GWL11 - Error 37 - Faulty Pump only or Computer/Controller too?
Hi just read your posting.If you are getting error code 37 then the fault is definitely your drain pump.If the pump is getting very hot, it is faulty.What happens is when the pump gets hot the thermal fuse that is part of the windings on the pump opens to stop it burning.I have seen this fault many times and always changed the pump.Hope this helps but please reply for further help.Looking forward to your reply.
2answers
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Problem with my LG washing machine WF-S7012DN model - 7 yrs old. Since yesterday, the wash/m starts to wash takes a turn or two and them stops with alarms on and flashing, (first time problem with my...
there is a magnet controlled switch in the top cover lid and the probable cause the magnet is missing.
The best alternative is just keep a good magnet on the top of lid & slowly move the magnet horizontally.At one point the BEEP stops & machine starts to function.
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
2answers
Code 39 err
Hi, Victor955
This is a Processor Rest Error
This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display.
And if needed unplug for 5 minutes to reset the system
Please remember to leave a rating.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
