Question about Hitachi 43UWX10B 43" Rear Projection Television
Blue screen w/ lines - called for repair
Repair company told us we need a "focus pack" for our Hitachi 43UWX10B when we called for service (when it's turned on the screen displays a blue screen w/ lines), and that the part is no longer manufactured.  I just found one online through partstore.com, but don't know if this is the right part and don't know who could install.    Any recommendation is appreciated.
  • 927 Answers
Good Day, cyndycallie;;
I'm glad you asked here. but if you have a blue pix with lines in it, then it could be that device. It also could be something else. Why not have the previous Company install the part? (PAUSE) If you don't trust this Co. ,have another come out and confirm the problem. Plus, if they are wrong it will cost them NOT you. Please call a Factory Authorized Service Center. Good Luck, big IRISH. PS come back if you need more help. I will even talk to the service Co.
Posted on Sep 01, 2008
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
The color are not focus reggie
If you are saying the red , blue and green are not lined up, this is called a convergence defect. IT requires 3 integrated circuits to be replaced. It takes solder and some time. you need soldering experience to do the repair. est. in our area of Columbus GA around 250.00
Please leave feedback
Feb 21, 2011 | Hitachi 43UWX10B 43" Rear Projection...
My hitachi model 43uwx10b has magic focas problem's red,green,blue and yellow are moon shaped across the screen
The two STK CONVERGENCE CHIPS AND ANY BAD RESISTORS AROUND THEM WOULD HAVE TO BE REPLACED.
Typical cost for all the parts on EBAY or Suburban Electronics would be under $25.
SD TECH
Feb 13, 2011 | Hitachi 43UWX10B 43" Rear Projection...
It appears the television has a convergence problem. I am pretty sure the red color does not line up with the blue and green. Is there a way to adjust the red manually? The magic focus does not fix the...
No not adjustable,Ur convergence it dead.Must replaced the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit to repair it ur self.The shop well cost U $300 for parts and labors.
Feb 06, 2010 | Hitachi 43UWX10B 43" Rear Projection...
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
HITACHI 43UWX10B Color Convergence
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Apr 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Color convergence red and blue will not line up/ double images
Repair involves some dis-assembly...replace convergence IC's
and inspect current limiting resistors for over-heat damage...
part # STK392-110 sub to upgrade STK394-160 Hitachi part # CZ 01341....you will need two....good solder technique required.
....................................................................................T.
Feb 08, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Magic focus
This might also be called digital array. You might have to do the manual adjustment with the cross hairs on the screen. These, one red, one blue, one green, should all align on top of each other in a white color. If this does not work, you should call 1-800-448-2244 for assistance in finding a local service center.
Jan 21, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blue/Yellow out of focus on Hitachi 43UWX10B
You will need the convergence circuit repaired......IC's replaced,
B+ resistors checked and then magic focus activated......T.
Sep 17, 2007 | Philips 60P8342 60" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
