Question about Packard Bell iMedia 6826 (P481000502) PC Desktop
Error message When trying to copy/move file to a flashdrive, an error message appears: message reads "Error copying file or folder. Cannot copy (Filename). The directory or fille cannot be created. I have searched in Device Manager only to be told there isn't a problem with the device. Thanks in anticipation
  • John Taylor Aug 28, 2008
    I have said my PC is a Packared Bell, when in fact it was built to my own specs.
  • Anonymous Dec 17, 2008
I had the same problem with a USB drive and a SD card. Both were only recieving 170 files to the root folder before I got this error. The solution was to reformat each using using 'FAT32' as the file system. This basically is a more modern file system that allows more files and cam about after win95. It looks like some USB drives and SD card are origninally formted with basic 'FAT'.
To reformat right click on the drive in windows explorer and select 'Format...'.
Another option if you dont need all the files in the root flder is to create a subfolder however this was not an option for me as my digital photo frame would not handle this.
Posted on Dec 27, 2008
I have just purchsed a 4gb usb2 flash drive . I am wanting to copy some pictures from my desktop and put them on my new laptop . Can anyone tell me how to do this in simple language as i do not understand...
Hi. All you have to do is:
- Insert your new USB flashdrive in an empty USB slot in your desktop computer.
- A new window will appear and will ask you what you want to do with that device... Choose "Open folder to view files".
- Then just leave it there and go to the file(s) you want to copy, right click on i and click "copy"
- Go back to your USB folder, right click on an empty space on that folder and click "paste". That will copy the files into your USB flashdrive.
- Remove the USB flashdrive from your desktop.
- Insert it into your laptop's empty USB slot.
- Highlight all the files you want to copy from USB flashdrive folder, right click and click "cut".
- Go to your laptops folder where you want to copy the files, right click on an empty space and click "paste".
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
HI GOOD EVENING I AM UNABLE TO COPY MY MICROSOFT OUTLOOK 2007 PST FILE TO EXTERNAL HARD DISK. AFTER STARTING COPY FEW MINUTES LATER I FACE THE FOLLOWING PROBLUM CANNOT COPY OUTLOOK:DATA ERROR(CYCLIC...
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Sep 07, 2010 | Computers & Internet
Error copying file or folder c annot copy xxxxx
try copying the file into a folder with different name
Mar 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error...
check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Jun 17, 2009 | Toshiba Satellite A45-S150 Notebook
Viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Apr 10, 2009 | Husqvarna Designer I
Can't Copy Files onto USB Drive
I think you have to copy the pictures to your flashdrive and not copy and paste. this is how to do it: highlight the pictures you want to copy to your flashdrive and check on the left side of windows explorer, you will see some commands available like (delete, copy , move etc) select the copy command and a small windows will appear for you to choose the location to copy, select the flashdrive and then click on copy.
this will copy the selected pictures with ease.
Feb 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2 GB Cruzer
hai,
it seems ur flash drive is infected with some virus
scan the drive with an updated virus scaner.
if this does not succeded, copy ur data to the HDD and go for a full format.
good luck
Please don't forget to rate or accept the solution
Jun 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you install and use a USB Flashdrive
just try this one. try to insert your flashdrive to a usb port where it is compatible then a message will appear saying open folders to view files then you can now copy and paste a pictures or songs on the pc or on ur flashdrve.
Feb 25, 2008 | Electronics - Others
I cannot copy iso games
try dragging the files into the folder you want, instead of just copying them. because your psp is recognised as a mass storage device, it will copy the files onto the memory stick when you move it instead of physically moving it like it would if you moved it to a folder on your hard drive. good luck!
Feb 01, 2008 | Sony PlayStation Portable (PSP) Console
Packard Bell iMedia 6826 (P481000502) PC Desktop Logo
246 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
