Indesit widl 126 s washer/dryer wont drain
Hi
This morning I wonke to find the red LED power light flashing fast along with 2 other green setting lights. When I opened the machine the water flooded out and the clothes were ringing wet. After setting the machine to drain I relised that the machine is not draining what so ever with a loud buzzing noise. Since then I have taken the kick panel off and unscrewed the filter thing,(flooded the kitchen and checked the inside area and it was clean). I have checked the pipe at the back of the machine conected to the sink drainer and there are no kinks and no blockages as far as I know. I am now at a loss of what to so next, can anyone help me? Is the pump in the machine broke maybe? If so how would you go about fixing that or replacing as it seems in a pretty hard position to reach? Is there anything else to checked when I unscrew the filter under the kickplate maybe?
Any help will be much appreciated.
Thanks
  • aerendur Sep 18, 2008
    I have the same problem with mine. It appears to happen when the load gets too high for the machine. Seems like a fail safe mechanism. Had it once before, last time it just fixed itself somehow after a dozen reboots and some water draining.
I have the same problem re: "This morning I wonke to find the red LED power light flashing fast along with 2 other green setting lights" But the machine will not open, ive tried using the drain setting, it seems to do the reverse, now machine is half full with water. There is no cycle with machine. 1 how do i open & if i did how much water would come out ( half a machine worth)? 2. Regarding reseting how many times & what did u do?
Posted on Jun 13, 2009
Ive fixed my problem by turning it on, and after it does the standard pumping part pull out the power plug. Then when you plug it in again it will completely drain and its all reset again.
Posted on Sep 18, 2008
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: i do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
Wont drain & wont open
We get to guess what brand you have.
Jun 13, 2009 | Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit WIDL 126 washer/dryer
look at http://www.indesit.co.uk/indesit/productsheet.do?productId=30538UK
Jul 06, 2008 | Computers & Internet
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
WIDL 126 S WASHER DRYER
what u can check is the outlet hose does it go down a plastic pipe if so pull it up slightly until it stops a simple mistake if its gone down slightly too much what happens is if its low down the pump kicks in as it thinks the pipe is lower then the washer to drain it try it if i isnt this then it will more then likely be a faulty timer which u will have to replace m8 let me know how it goes m8
Dec 13, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
968 people viewed this question
Top Washing Machines Experts
