Question about La Pavoni Espresso Si PAB-16 Espresso Machine
Pavoni espresso machine-heating broken - La Pavoni Espresso Si PAB-16 Espresso Machine
  • 515 Answers
Is the machine dead?
Posted on Aug 30, 2008
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
May 22, 2014 | La Pavoni Coffee Makers & Espresso...
Tip
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
I need 120 v 1500 WATT TRIANGULAR FLANGED 2 PRONG HEATING ELEMENT FOR A PUBV1
You can check with Espressopartsnw.com or crossroads espresso(coffeestuff.com) they are the pavoni distributors.
Apr 06, 2011 | La Pavoni Pub V1 Espresso Machine
Handle problem
The bigggest pavoni dealer I know of is crossroads espresso 15413444600.
May 02, 2010 | La Pavoni Club Combo Duet PA-1315 Espresso...
I have an europiccola from the 79s that i got off the internet. I can't get it to heat up. I know the fuse is good, the switch is good (i check both) so is the only think the heating coils? If so where can...
If you check the coil with your ohms meter and get no reading then you might be able to find one from crossroads espresso they are the biggest Pavoni dealer 15413444600.
Apr 30, 2010 | La Pavoni Europiccola EPC-8 Espresso...
My La Pavoni Europiccola "exploded" this morning - I think it is the heating element. Is that a common problem - how expensive and easy is it to fix the machine?
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Jul 14, 2009 | La Pavoni Pisa PA-35 Espresso Machine
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Heating
Try to descale the machine to make sure you not have any calcium in the boiler.
/Mirran
Aug 28, 2008 | La Pavoni Espresso Si PAB-16 Espresso...
La Pavoni Espresso Si PAB-16 Espresso Machine Logo
141 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
