Question about Autotek SX280 Car Audio Amplifier
Blown subs i have an 800watt 2 channel autotek amp which has worked fine for around 4 years. then my subs fried. i bought a new sub and this also fried after around 30mins use at medium volume levels any ideas? thanks
  • glennmaynard Aug 28, 2008
    it is bridgeable i think its the sx-2300 i was running 2 x diamond 12" 300w rms dual 2 & 4 ohm wired parallel the amp temp is fine just keeps popping subs
    Sergeant:
  • 241 Answers
HOW do you have it wired and what is the ohms rated on the subs
and is this amp bridgeable and at what ohms is it stable at
Do you have it Bridge to the subs to lower the ohms( Series or in Parallel)
Is the amp running hotter the normal and do you have it in a well ventilated are of your car/truck
Most car audio or at 4ohms and also is the subs dual
Posted on Aug 28, 2008
  • Jayson Brollini
    Jayson Brollini Aug 28, 2008
    Are the subs rated at high enough Watts to handle the amp
    and the subs ARE blown or are the making a scratching sound
    Is the Subs wires + - connected to the coil and the sub frame(metal)
    I am just wondering what you mean by fried ( A blown Sub can be several things that can be repaired!)
    Now the Amp is powerful and it sound like nothing is wrong with it.
    Now do you have a capacitor going to the battery, because you battery can send SPIKES (high volatage/Watts) and this would cause your amp to produce higher amount of watts>
I have a kenwood excelon xr-4s amplifier and in channel 1 and 2 i have front speakers, in 3 and 4 i have a infinity kappa doble coil 4ohm each coil. When i turn it on loud it shut down the amp and start on...
Since you have two dual 4 ohm voice coil subs, hopefully you had one sub wired in parallel to each channel separately (one sub on 3, one sub on 4). That way, each channel gets 2 ohms. If you have both subs bridged across channels 3 and 4 (left + and right -) then you have applied a 1 ohm load to your amp, which would cause the problem you're having. It's possible the amp has been damaged, but the fuses on the amp should have blown to protect the amp. Check your sub wiring to make sure you don't have a 1 ohm load bridged across channels 3 and 4. Also check the fuses on the amp itself to make sure neither of them have blown. If everything is fine there, check your fuse under the hood that's connected to your battery. That fuse could have also blown.
Nov 14, 2017 | Car Audio & Video
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Blown subs
check all the connections are good even hook a sub up to and cd player to see if it works if it does it will be the amp
Aug 28, 2008 | Autotek SX280 Car Audio Amplifier
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Amp has 3 modes on it ,as a switch,what is this,it has a 2,3,4 channel mode,i have the gold dhd 1000watt x4 channel
first thing 1000@4 means 250w per ch. which means150w usable power.the mode switch is only to reduce rca cables,use 2ch mode if only 1 pair rca available,60hz is a bit low for this amp,90 would work better.
Aug 21, 2007 | DHD NTX-2009 Car Audio Amplifier
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Autotek SX280 Car Audio Amplifier Logo
88 people viewed this question
Top Autotek Car Audio & Video Experts
kli99gunrunn
Tom Chichester
FastHarley
FastHarley
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
