Question about Honeywell Heating & Cooling
I need to reset my RTH221B home thermostat, it is now set at 79 and i want it at 70
  • 639 Answers
Friend,
Happy to assist you,
Go online to Honeywell and download or order the user manual Instruction are in there with a a diagram!!
My words alone will not remedy the situation!
You need to call service !!!!!!!!!!!!!
LET ME KNOW WHAT HAPPENS???
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
Is the thermostat ac or dc (rth221b)
This thermostat is 24 volts A/C. Here is the operational manual and the install manual for the rth221b. For more information on thermostat power check this link.
Jan 19, 2012 | Honeywell Heat/Cool Thermostat
Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Installed my thermostat and the heat keeps climbing where did i go wrong? it is a honeywell Honeywell RTH221B Basic Programmable Thermostat
Make sure red wire is on R terminal, white wire is on W terminal. Also look for a short in the thermostat wire.
Oct 17, 2009 | Honeywell Electronic Programmable...
Want to replace analog Honeywell thermostat with digital
Your system uses 24 volts and that thermostat should work. You should only have a two wire system and that should work using the RH and W connection on the thermostat. My personal opinion about that thermostat...I don't like it. It will timeout for 15 minutes after furnace does not fire up. I deal with this thermostat all the time because that is what they install in the new homes. I always have to pull it off the wall, remove the batteries and wait for it to completely drain power becuase it does not have a reset switch. Very irritating...Might be too complicated for your application.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
I need the wiring diagram for the honeywell RTH221B
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Hank
Oct 15, 2009 | Honeywell Programmable Thermostat Heater
How do I program my honeywell basic thermostat?
Go to
Oct 10, 2009 | Honeywell Programmable Thermostat Heater
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
209 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
