Question about Yamaha RX-V659 Receiver
Center channel drops once unit warms up
Once the unit has been on for 15 to 30 minutes the center channel looses all sound.
You don't have an external amlifuer, do you? You could hook the pre-amp out for the center channel to an external amp and connect the speaker to the amp. That way you could determine if it is the center channel output or the internal amp. Either way you probably need to get it serviced.
Best Regards,
Posted on Sep 17, 2008
I recently dropped my amp after a gig and once I hooked it back up only one channel works. I noticed upon start up after the fault lights go out I would hear two clicks .. now I only hear one. I'm...
I am a musician myself (classic rock band) I too have a crown two Chanel amp , only difference is ours is a 3000. Well don!t feel bad. I had dropped mine more than once and your right, when you turn it on you hear two clicks, one for each side, those are relays that trigger the power to come on and like warm up. I dropped mine one time and both sides were not clicking at all, so I took it apart ( lid off, unplugged of course) located the relays which were pretty easy to find as they were the first switch from where the internal power plug comes in, I moved them around, got lucky, they got loose from when I dropped. Then happened again by a helper, and this time no help. Went to guitar center and they took unit and replaced them, about 40 bucks. That was a couple years ago. Point of my story, this problem seems as mine, and I believe it is going to be a loose or broken relay for that side chanel. Thanks mike, hope this helps.
Sep 01, 2011 | Crown CE1000 2-Channel Amplifier
When trying to watch a dvd through a blu ray player, the background sound is coming in loud and clear, however when the main actors talk, their voices are not coming through.
If you don't have a center channel you will experience this problem. The center channel is where all dialog is sent to. To fix it, you need the set the receiver to phantom center. Go into the setup menu into speaker setup and tell the receiver that you dont have a center channel installed. Once you do that, it will send dialog the the front left and right speakers.
Good Luck
Jan 07, 2011 | Sony STR-DE575 Receiver
Denon AVR-589 Center Channel Fault: I have a Denon AVR-589 that goes into ASO / DC protection and I've narrowed it down to the Center Channel. Instead of cycling thru various voltages on startup before...
For something to trip the protection circuit, it must be shorting somewhere. My bet would be an output transistor or IC, but if you think they are good, a bad capacitor would also do the trick. If the top of any electrolytic looks odd or there is any stuff coming out of them replace them.
You might want to look at the "Bad Caps Forum" website, it lists known capacitor makes that are known to cause trouble. If you see any them replace them.
Mar 19, 2017 | Denon Audio Players & Recorders
The amps in the receiver turn off and on all the time. The center channel rarely works, and the left & right channels turn off & on every 10-15 minutes as well as the subwoofer output. Is there...
loose connections,issues. disconnect center and front speakers from this receiver. turn on with rear and subwoofer. horrible sound but the point is it will eliminate the speaker issues and confirm loose connection if the receiver continues to behave the way you described.I have repaired a few for loose connections.
Mar 01, 2010 | Sony STR-DE975 Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Dont know how to set my crossover! mtx rt-x03a
This unit had a couple unique features: a center channel (summed) output and a differential output (right channel is subtracted from the left). Once you figured out you lows, mids, and highs. Center and rear. I recommend buying a cd to test out your sounds like your high, mids, and lows
Mar 06, 2009 | Car Audio & Video
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Right center channel doesnt work.
Is there a loose connector on the inside or a loose wire?
Aug 07, 2007 | Pioneer VSX-816-K/S Receiver
When switching devices I loose audio after a few minutes after power on.
have a tech check your set for lose solder or possibly the audio circuit.good luck.
Apr 19, 2007 | Kenwood VR-5090 5.1 Channels Receiver
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
143 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
