If you very carefully prise off the inner trim of the door you should be able to see where the lug broke that was originally holding the screen. Use a small cable tie to fix one end of the spring to one a the angle pieces of metal around where the window is, about the same level (make sure the other end of the spring is on the hook assembly). You can secure the cable tie and adjust how tight you pull it to get to roughly the same tension it would be if still on the original lug. Cut off the excess of the tie and clip the frame back in position. Door should open and close now. Hope this helps
if this is alap top make sure the ant. is hooked up push blue fn+hold ago to f1 f 2 orf3 should have picture of ant. holdblue fn+push ant key this should solve your prob.
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd playerto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Same thing happened to me. For about $5, I went to Home Depot and bought 24 gauge wire (about 5") and a pack of black heat-shrink plastic sleaves (1/8th inch or 3/16) from the electrical department. The 24g wire fits perfectly through the rubber slot after you pull out the broken ear hook. Use a pair of pliars to bend the wire to shape your ear (use the broken jabra ear hook as a template). Once you have the right shape and have filed down the sharp edges, slip the heat-shrink plastic sleave over the wire, making sure you leave the end piece that goes into the slot of the headset as bare metal. Use a hair-drier on high-heat to shrink the black plastic. Mine has worked perfectly for over a year and actualy fits better than the original.
connect yellow white and red cables FROM AUDIO/VIDEO out from the dvd player to the tv. connect your cable wire or coaxial cable to this unit. (the first one is going to be on your tv disconnect that one and put it on this unit where it says ANT IN.) connect the cable that came with it on ANT OUT or a cable that you might have and then turn on tv. and use your original remote to your television and look for a button that is regarding input or tv/video or tv/av. This function will only be on your tv remote. NOT DIRECT TV.
