SOURCE: i have an acer aspire
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Acer Website
SOURCE: how do i restore my
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form.
SOURCE: I want to restore my acer aspire 4315 to factory
well good news maybe on start up press the alt +f10 or ctrl+ f10 and this will put it through to factory restore and hopefully it will not ask for youre password finger crossed if you do get in it then write the restore disks for next time using epowering tech it uses 2 dvds on mine and mine is the 7730 gud luck
just done some research and the default is 000000 try that out
i had sometime on my hands re download it from herehttp://www.acer.co.uk/acer/service.do?La... let me know if this does it if not ill keep trying im bored lol
before you do it just check the model i have entered is the same as yours ?
good luck
my guess is its the framework you need
SOURCE: Acer Aspire 5920 factory reset
Then you need the Windows OS disc and drivers. You should've done a backup disc when you first got it.
SOURCE: i want to factory reset acer aspire 3630
Unplug your system from the wall outlet, open your case, and touch a metal component inside the box to equalize static charge; then remove the motherboard battery. Wait 5-15 minutes, replace the battery, and your machine will be back to default state.
