Question about Sport & Outdoor - Others
06 kawasaki jet ski wont start
Jet ski ran great last summer.It sat for 10 months and now wont start. Replaced the battery and still nothing. the guages dont even move
  • 1 more comment
  • cdwarren1971 Apr 10, 2009
    I have a kawasaki 900 STX jet ski. I replaced the battery and the spark plugs (3 plugs). The engine turns over but it will not crank. Is there anything I am missing?
  • Cole Ritz
    Cole Ritz May 11, 2010
    Ok , I think I might have some suggestions. In 2-stroke engines there is a CDI electrical device. This device is like other electronics and is very sensitive to voltage/blips in voltage. I know from expierience that these devices can blow a diode or the whole CDI just from a close lighting strike!!!! The only other problem that I could think of is that the fuel/fuel lines might be dirty or filled with old gas. The other thing is that 2-stroke engines are very temprimental when it comes to flooding the engine with too muck gasoline at once. When this happens in a 2-stroke engine the spark plugs become "gummed' (When the 2-stroke oil in the gasoline mix gets all over the plugs drowning the plugs contact with the engine which blocks the spark from happening. If it is a 4-stroke then I would go to a dealer and have them look at it.
    Hopethis helps!!!
  • Anonymous Mar 20, 2014
    No fire to engine
Check the fuses! I have two 900zxi's brand new batteries and brand new plugs,
Fuses are in the electrical box under a black cap(depending on model)
Posted on May 10, 2009
I have come across this problem many times first make sure you have a fully charged battery remove plugs and spin engine over with your throttle fully open to clear the cylinder bores of any dirt or old fuel change your fuel as old fuel will loose its octane quality and the 2 stroke mix will seperate from the gas over time change plugs and before you spin engine over place a couple of drops of mixed fuel down each carb and see if it fires up if it does then stops try again you will prob have old oil gummed up in your fuel pump hope this helps.............
Posted on Apr 12, 2009
  • 3 Answers
Hi check the earths onto the engine and engine mounts also check all main connecters and battey termenals for corrosion if this doesnt work youll knead a multi meter to check yor continuaty
Posted on Dec 29, 2008
    Problem Solver:
  • 34 Answers
Oh. One more thing..... before spending money on repairs just try changing the plugs.
Posted on Aug 30, 2008
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Jet ski loses power when it gets hot
are all cylinders working ? carbs might need cleaning ! what compressions have you ? 100psi min !!
Nov 15, 2013 | Tempest Kawasaki Jet Ski 1100cc JT1100 STX...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
My 1991 Kawasaki JS440 jet ski won't start and it
You might want to post this question in a different section. This is the computer games section.
Aug 23, 2012 | Video Game Consoles & Games
1998 kawaski jet ski that boggs down on take off
Sounds like this bike sat for a while. When carburetors sit, the jet's inner diameter shrinks slightly from oxidization/micro-corrosion, and the diameter of the needles that go through them grows for the same reason.
Replace the jets and the needles that go through them.
I had this problem with a Suzuki GS850. When I fixed it, I treated the bike as I had been before I fixed it on the test drive, and almost launched myself off the back of the bike when I first opened the throttle. Careful.
Jul 08, 2010 | 1998 kawasaki GPZ 1100
Jet ski wont start, no lights no nothing,, battery is new and been tested twice
Check your ground wire, and also check to see if you have a fuse/fusible link that went out.
Jul 14, 2009 | Encore Software Kawasaki Jet Ski...
Kawasaki 550sx won't start
souds as if the starter is faulty. Use a volt meter to check voltage at the starter while holding the start button. If you get a battery voltage reading, then the starter is shot.
Mar 22, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
1,048 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
