Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Right blinker not working
Left blinker works fine,right side doesn t work at all.
  • jlawtry Aug 28, 2008
    My lights work,the right blinker willnot blink. Sometimes when I turn right on the left will blink sometimes.
    Genius:
  • 2,028 Answers
This is generally a loose or broken ground wire that causes this. It could also be in the switch, you can test the switch by pulling the **** shell apart exposing the switch, and using a piece of wire, jumper across the connection wires. If you can get the signal to light this way, then it's a faulty switch. It doesn't need to blink when jumpering it, just light up.
Posted on Aug 28, 2008
  • Ryan Rogers
    Ryan Rogers Aug 29, 2008
    O.K. This is going to be in the blinker relay. Your bike has a relay that allows the signals to blink same as a car. In your post you said the right didn't work at all, so you can see how I interpreted that as no lights. I don't have the bike in front of me, so you have to be clear on the problem. Change the relay and it should work fine.
Right blinker makes both back blinkers flash but only the right on the front
I would suspect the turn signal switch is defective. Do not place any parts until an qualified GM tech has confirmed this guess.
Jun 08, 2012 | Cars & Trucks
'96 cadillac eldorado left blinker blinks fast
Have you checked to see if you have a blinker out? If you do, then thats your problem. If not, check your blinker fuses. Hope this helps, James Booth.
May 17, 2011 | 1996 Cadillac Eldorado
Blinkers
You can check your blinker relay located in the fuse box. You should have 2 of them. 1 is for the emergency blinkers. Trade them to see if this corrects the problem. The other issue could be the multi switch is not functioning properly all the time.
Apr 28, 2010 | 2007 Ford Fusion I4 SEL Sedan
Right blinker dead left blinker works 2002 buick lesabre limited
RIGHT BLINKER dead ,front,back, or both..???? If front works, and rear doesn"t (REPLACE REAR BULB).....and vice a versa....If rear and front both don't work replace the FLASHER ..Flasher is located in the FUSE block area.......Listen to the operation of the LEFT or RIGHT flasher operation and you should notice a dirrerence....
May 17, 2009 | 2002 Buick LeSabre
Right blinker does not blink
check your bulbs one is not working properly it can be either the front bulb or the rear bulb you can swap then with the left side and see what happen
Mar 27, 2009 | 1995 Plymouth Acclaim
Lands Phones Logo
153 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
