Question about Pentax Optio S40 Digital Camera
Optio S40 Battery issues
The other day I turned on my camera, it said batteries were depleted, so I went out and got some new ones (AA's) popped them in, still says the batteries are depleted! I bought another brand, and still same problem. Anyone have any suggestions? It's pretty new, haven't had this issue before, and I have changed the batteries a few times already...
    Master:
  • 542 Answers
I've had this problem. The S40 is *really* picky about good connections for the contacts to the batteries. Make sure you use a facial tissue or something similar to wipe off the ends of the batteries to take off as much finger oil or what have you. Then when the batteries are inserted into the camera, spin them around a couple of times to ensure that contacts have a good connection then wipe the tops of the batteries again and close the battery cover. I've had the same problem with NiMH batteries that I've had no problems with *ever* in other digital cameras and game boys. It probably has something to do with the small prongs that pentax uses on the battery contacts.
Posted on Sep 08, 2005
Battery depleted
Hi there - I just experienced this problem with a Pentax Optio S30 (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Feb 01, 2011 | Pentax Optio S50 Digital Camera
Camera optio e40 pentax shows the battery life as depleted even tho they are new batteries I have tried any new AA batteries 1.5 then I tried rechargagles at 1.2 for digital cameras.
this is not malfunction.
According to its manual, just turn it off ,wait for one minute and
turn it on again. It'll reset th camera. You need to reset the date/time.
Dec 25, 2009 | Pentax Optio E40 Digital Camera
I have a pentex optio m60 it was okey but suddenly it saying battery depleted could me please tell me what is the solution for that and why does it happen
There could be a couple reasons for this:
1. When you have the battery in the charger, does it indicate that the battery is dead or fully charged. I would suggest placing the battery in a universal charger to check to see what the rating is on the battery, a universal charger will indicate the true power left. If the universal charger shows the battery is drained but your charger says it's full, you have a bad charger. If they both indicate full but camera says dead, you have either a power supply issue in the camera or the main board cannot read how much life is actually left in the battery. If your charger says full and the universal says empty, your battery is malfunctioning.
2. Does the camera turn off when it says battery depleted or does it simply keep telling that it's depleted. If the unit doesn't shut off, you have a firmware issue that needs technical repair on. That specific model does not allow you to download updates via USB from your computer, you need to send it to Pentax for repair.
Dec 08, 2009 | Pentax Optio M60 Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Depleted Batteries
Clean the contacts in the battery chamber to get to the bottom of the chamber use an eraser on the end of a pencil Also the top contacts. you could also try packing out the contacts on the tops of the batteries to ensure good contact.
Sep 14, 2007 | Pentax Optio S40 Digital Camera
S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Mar 21, 2007 | Pentax Optio S50 Digital Camera
Can't get my camera to turn on
Try rechargable batteries or Duracell. Other batteries may not have sufficient charge.
Aug 24, 2006 | Pentax Optio S40 Digital Camera
Shutter lens won't go in
If I remember right it takes AA batteries. Correct? Perhaps one of your NiMH AA's is not charged properly. Try it again with two newly charged NiMH batteries. You might also try putting in two newly charged batteries and let it sit for 24 hours and then turn it on. Lastly you might try putting a little pressure on the lens when you turn the power on. I had to do this once with my Optio S4. Hope you can get it figured out.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Pentax Optio S40 Digital Camera Logo
310 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
