Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door stalls
WHEN THE CODE IS ENTERED TO OPEN THE DOOR, THE DOOR MAKES A LOT OF STALLING NOISES AS IT ATEMPTS TO OPEN AND TRAVELS JERKINGLY FOR ABOUT 12 INCHES AND THEN STOPS. IF I PUSH THE OPENER AGAIN IT GOES DOWN AND UP AGAIN AND OPENS ALL THE WAY. WHAT COULD THE PROBLEM BE?
  • IDLG Aug 29, 2008
    it is not a stone. what else could it be?
    Genius:
  • 1,269 Answers
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Posted on Aug 29, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Spring has broken. you need to replace them in pairs. if you have safety cables the carcass should be suspended upon it. Occasionally spring is ok and cable is found to be broken, again replace broken item in pairs as the other cable is likely worn equally.
thanks
good luck
    President:
  • 1,952 Answers
I am trying to figure out how to reprogram the code on my craftsman keyless entry pad model number 139.53876.
    Master:
  • 521 Answers
Re enter the code properly and see .check the tension of the springs.
Posted on Aug 28, 2008
  • tech expert12 Aug 28, 2008
    Check the sensors in the doorway. They need to be pointed at one another. Each of them has a small light that is lit when they are aligned properly.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
  • 19,396 Answers
If the door makes noise there is either an obstruction or the gear are stuck, this is not a control problem.
  • Ginko
    Ginko Aug 28, 2008
    Try closing the door all the way throught and opening back a couple of times.
    Check that there is nothing obstructing the door in its path, fo example a small stone stuck in the hinge arms.
    If you do not find anything visible you will need to take apart door opening system and find where it is mechanically obstructed.
    If you need a technician you can call the number listed on Liftmaster owner manual.
  • Ginko
    Ginko Aug 29, 2008
    Grease and dust mixed inside the gate gears return same problem sometimes, usually, when you cannot find a simple soution you need to hook out pinion gears from the gate, and check out if door alone is moving, or if it is a problem with motor and geards getting stuck.
    If the unit is less than one here old it is covered with factory guaranty.
Sqealing and stalling
see if it does this with the a/c off compressor could be hanging up something is putting an extra load on engine check all fluids transmission torque converter could be trying to lock up are their any codes
Jul 06, 2012 | 2005 Ford Freestar
Garage door stalls when opening or closing intermittently.
Tries unplug,replug it back like about an hour later,the a/c power cord for the motor.The motor unit should be resetting it self back to the factory setting.The problems,should be solved now.If not the motor unit have problems,must be replaced.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security+ - enter code on keypad and background light blinks and door won't open. How do I get door to open?
Try programming it by pressing and immediately releasing the smart/learn button and then walking over to the keypad and keying in your four digit code and press enter. If this doesn't work your keypad is bad.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 3 stall garage with two garage doors, we also have 3 garage door openers. When I push the button on one opener both doors open or close. How can I fix this?
You will need to clear the memory of both openers by holding the smart/learn button in for 6 seconds. After doing this none of your remotes will work but your wall control will. Now you need to program the openers making sure you don't program any remotes for both doors.
Dec 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR
two things to check...use the disconnect handle where it attaches the door to the opener, then see if the door will open manually easily, if it does, the door is ok, if it doesn't LOOK at the springs that raise it. DO NOT try to adjust the springs yourself!!!!! if one of them is broken, call a service Co. to handle the repair. Also, check if the door is level. an easy way to eyeball it is to look at the rollers in the track while the door is closed. they should all be the same distance between the hinge on the door and the track. NEVER TRY TO MESS WITH THE SPRINGS!!!!!! THEY CAN SEVERELY INJURE YOU!!!!!!!!!!!!
Sep 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
103 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
