Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge profile side by side
The lights in the door and the inside freezer light goes out when trying to dispense ice or water as well it kills the fan inside of the freezer. It still makes ice ok but when it happen it happen over night. If its not the connector at the bottom of the door how hard will it be to change to other part you mention and where is it located? Or will I need to get technician to come out?
  • 74 Answers
To change the main PCB is relevantly simple as it is situated on the back of the appliance under a metal cover held on by about 9 screws. I would double check that the light switch is working properly also as i have experience of poor connection on the light switch terminals causing issues with not dispensing.
Posted on Sep 02, 2008
How do I remove the ice/water access panel on GE Profile fridge? The ice dispenser, water dispenser, and all lights stopped working.
First, open door to freezer, while pushing in on the ice dispenser trigger look at the lights in the freezer and see if they go dim, if they do then the "main board" on back of frig is defective. This is a common problem with these boxes. Its somewhat uncommon for the ice, water and light to go out at the same time, its possible, but not common.
Another way to tell if main board is bad is when you do as stated above and you hear the evap fan stop then main board is for sure bad.
Let me know what you find out. If main board then I will need model & serial number to give you the right part number for main board.
If none of the above occur, then advise and I will tell you then how to pull dispenser apart.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Not getting water from dispenser in door
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Dispenser on freezer door
Check the electrical connector at the bottom of the freezer door for corrosion and if it is not that then the main PCB is failing , when it fails the appliance will stop working altogether although the lights will still work inside.
Jul 17, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
