Question about Epson Stylus CX3200 All-In-One InkJet Printer
No color ink cartridge
It has been awhile since I've had my Epson Stylus CX3200 hooked up to my computer and had ink in it. Now I've hooked it up and turned it on to copy something. I only have black ink in it and the message on the front says " No color ink cartridge-- Press color copy button to install new ink...". Do I have to have color ink in it as well in order to copy even just black and white?
  • Anonymous Sep 28, 2008
    my ink cannot recognize even i have
    Problem Solver:
  • 5 Answers
Yes you do, the printer requires both ink cartridges.
Posted on Aug 30, 2008
Bought new cartridged, replaced the old one but the content is not getting printed
Check the control panel for error indicators. The error light is to the left of the display and is marked "Error," it will illuminate. The error will appear on the screen and is in plain English, so very simple to interpret. An example is "Color or Black Ink Out," meaning there's no ink.
  • 2 Verify that the Epson Stylus CX3200 is connected to the printer with a cable. Try connecting without a USB hub while troubleshooting---that way you can identify if the problem is with the hub or printer. Replace the cable, it may be bad.
  • 3 Print a nozzle check pattern to determine the extent of the problem. The nozzle check will allow you to determine whether the printer will print at all, and the results will give you a good indication of print problems. Press the Menu button on the Control Panel until you see Nozzle Check and press the Color Copy button.
  • 4 Replace the printer cartridges if the Control Panel suggests you do so. Press the Menu button until you see "Change Cartridge" Press the Color Copy button and the cartridges will move to their change position. Lift the scanner and unclamp the cartridge. Replace the cartridge---color is on the right and black on the left. The Epson Stylus CX3200 will start charging the cartridge and after about thirty seconds the printer will be ready for use.
  • Feb 07, 2011 | Epson Stylus CX3200 All-In-One InkJet...
    Epson cx3200 printer has printing problem
    Hello cockie ,
    You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
    If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
    It may also be helpful to try running a printer nozzle check.
    See the following message problems and solutions:
    Error Message Probable Cause No color or black ink cartridge - - >
    Press the Color Copy button to install a new ink cartridge.
    The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
    Press the Color Copy button to begin replacing the ink cartridge.
    The indicated cartridge is out of ink Ink cartridge error - - >
    There is something wrong with the ink cartridge. Paper jam or misfeed - - >
    Press the Color Copy button and clear the paper jam by hand if necessary.
    Paper is jammed. Press the Color Copy button to clear the jam.
    See the User's Guide for more troubleshooting tips.
    Paper out - - >
    Load paper in the sheet feeder and press the Color Copy button.
    Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
    Close the scanner unit.
    Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
    See your documentation and call Service if necessary.
    Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
    Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
    Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Epson stylus cx4300 series is not printing because there's no black ink but colored ink cartridge are almost full.
    Hi guys i need help
    i have problem printing to the epson cx4300,it s not printing black,i have change the ink tested it,made sho that the ink is not dry,reconfigured my computer but still,uninstall drivers reinstall on the computer.it jus not printing,what is the problem.
    please help
    Dec 05, 2010 | Epson Stylus CX3200 All-In-One InkJet...
    Epson Stylus C3200 Red Error Light Stays On
    Ink level at chip reach zero. Reset ink level counter using hardware resetter. Or Use CISS chip with autoreset.
    Jun 15, 2009 | Epson Stylus CX3200 All-In-One InkJet...
    Error inkcartridge
    Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
    Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
    Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
    Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
    Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
    Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
    Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
    Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
    Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
    Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
    Error Message: Scanner unit open -- > close the scanner unit
    Solution: Carefully close the scanner and press it down until it clicks securely into place.
    Error Message: Scanner error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
    Error Message: Printer error -- > See your documentation and call service if necessary.
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
    Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Help Epson CX3200
    I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
    Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
    May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
    Ink not empty
    You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
    Full info on how to get out of this is on my site.
    Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
    The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
    I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
    For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
    When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
    I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
    If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
    Happy trouble free printing
    The INK Store (UK & Europe)
    Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
    Blank pages
    Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
    Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
    Color, black ink cartridge error
    contact epson support
    they may replace your cartridge
    Oct 24, 2007 | Epson Stylus CX3200 All-In-One InkJet...
    Epson Stylus CX3200 All-In-One InkJet Printer Logo
    67 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
