Acer Aspire 3002LCi Notebook Logo
Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY ACER ASPIRE 3002LCIPC LAPTOP WILL NO PROCESS PASS THE WINDOWS STARTUP
I added a security program. Scanned the documents and found 1 virus file. Application/Regcure_1_5.exe file. The program can not disinfect this. How can I get passed it. No sure what to configure in the utilities section if any??
*No incons showing, no nothing. I can get to f2 setup (BIOS)
Tony Budz
Level 2:
  • Expert 162 Answers
  • Posted on Nov 22, 2008
Tony Budz
Expert
Level 2:
Answers
162
Questions
Helped
33564
Points
292
Unfortunately your in a state where you need to
1. boot into a dos based application and run a virus remover.
2. slave that drive to a clean master that's protected with virus software
3. blow the drive away and start over.
sorry
t
Cant find scanned document on my Aspire how do i find?
Going with it's an Acer Aspire 5315 Notebook PC, which according to Acer Support comes with Windows XP (Home or Pro), or several basic versions of Windows Vista,
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5315/Aspire5315sp2.shtml
WinXP:
1) Desktop screen
2) My Documents; Click on Start, then on My Documents
3) Downloads; Click on Start, then on My Documents. DOUBLE-click on Downloads.
Win Vista:
1) Desktop screen
2) Documents; Click on the Windows logo button, then on Documents
3) Downloads; Click on the Windows logo button, then on Documents. Then click on Downloads.
Anyway you can try scanning a document again, and see where scanned files go? Then delete the scanned file.
Look at the window, and what is stated at the top. This is where the scanned file will go.
Regards,
joecoolvette
4answers
Why is my laptop so slow? And how do i reboost my laptop without a c.d
> Why slow?
1. dying disk-drive, that takes a few attempts to read each file;
2. not enough RAM to run "too-many" simultaneous programs;
3. computer-virus;
4. slow Internet connection.
> without a C.D. ?
Either telephone Toshiba, and order a replacement CD, identical to the one they supplied when you bought the computer. Or, look for a program installed on your computer that you use to "burn" new CD/DVD disks, to create the "System Recovery" set of disks.
Slow acer logo loading
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
2answers
My aspire 3680-2633 is running super slow! How can I get it some speed
There are two possible reasons for computer running slow:
1. A lot of applications are installed and the Windows is trying to load all during the startup process
2. The computer is infected with virus
Try uninstalling some softwares and also scan your computer for virus
If the issue still persists, the I would suggest a full system recovery, you can restore the computer back to factory default,to do so, follow the below steps:
Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
2answers
I have an aspire 3053 laptop it is so slow its unbelievable is it possable to change the memory to speed it up its about 3 year old
Is your computer running Windows Vista Home Basic?
Does it have 512MB of RAM installed?
If yes to both questions, then adding 2048MB of RAM will _definitely_ speed-up your computer.
See: http://www.pcmemorystore.com/Acer-Aspire-3050%5E1733-ram.htm where you can buy 2GB (2048MB) of DDR2-4200 RAM for $38 US.
The usual cause for a "slow" computer is too-many programs running at the same time (not too many programs installed onto the disk-drive) competing for too-small amount of RAM.
Turn the computer off.
Disconnect the AC power-cord.
Flip the computer over.
Remove the battery.
Remove the screws over the memory cover (at the centre of the bottom).
You'll either see a stick of RAM, or an empty slot for RAM.
Remove any existing RAM, and insert the new stick of RAM.
Replace the cover.
Insert the battery.
Connect the AC power.
Boot it up, and it will run _MUCH_ faster.
I have an acer aspire 3680. I started up my computer and it said replace hard drive, immenident failure possible. It gave me the option to run startup repair but as is going thru the process, its keep...
Sounds like a virus. Remove the drive from the laptop and connect it to another computer using a USB cable. These cables can be purchased for around $20 from tigerdirect.com or compusa.com. After it is connected, scan the drive for viruses using your desktop antivirus program. If you do not have an antivirus program, I recommend that you download Microsoft Security Essentials for free from Microsoft's download site. http://www.microsoft.com/Security_Essentials/
Cant close down my acer laptop have to use the power button each time?
ou might want to run a spyware/virus scan. Seems like some process is running that your system can't kill during the shutdown process.While you're at it, you also might want to check your startup environment and see if there's anything in there that shouldn't. Clean out your temp folders...
c:\windows\temp
c:\documents and settings\<your account>\local settings\temp
c:\documents and settings\<your account>\local settings\temporary internet files\
...and install current patches & hotfixes.and for more info contact http://tinyurl.com/m7ghqz
1helpful
2answers
Laptop no longer functions past blue acer aspire screen
Are youable to move your mouse pinter, it sounds like it's freezing on logon prompt, or if youhave only 1 user at your desktop. either way if you canreboot into safe mode by pressing f8 as it bootsup, then if you have some antispyware program run it. if you cant get into safemode, take the HDD out of your computer and scan it on another Pc that has an upto date virus/antipsyware program.
Failing that from safe mode again, modify the startup entries from the registry using "regedit" and remove anythign that looks dodgy.
If that doesnt work, you can run a repair install of windows, but for this you need to disc used to install the OS. this is LAST RESORT of nothing else works, and i would not reccomend doing this if you are not familiar with installing operating systems, as if you choose the wrong option it may wipe your pc.
try simpler options first. antispyware is most probable cause.
LAPTOP ISSUES
Virus Gards normally does that...it suspects programs...You have to add it to trusted zones...and skip it's when it is getting scanned....
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
