DELL M170 LAPTOP HAS A BLACK SCREEN WITH POWER TO THE SYSTEM. REPLACED VIDEO CARD, FAN AND CPU HEATSINK. CHANGED THE POER CORD. SCREEN GOES BLACK ON SYSTEM AND EXTERNAL MONITOR. THANKS!
O n most dell laptops right at the base of the screen is a panel that pops off. If so there is a small card about 1-2inches wide ans 3-4 inches long. It is above the keyboard. this is an aux. power board and should have a connection on it to help power the screen. If this model dosent have this poard than the built in screen cooler is bad and you will have to replace the whole screen.
THE COMPUTER BOOTS AND RUNS. IT STAYS POWERED ON BUT THE SCREEN GOES BLACK. I HAVE SWAPPED OUT THE MEMORY AND IT IS OK.IT HAS A NEW FAN AND IT WORKS.THANKS!
The computer screen stays on for about 7 minutes. The computer boots and stays powered on until I power it off.Thanks!
Actually the screen saver is set for 10 minutes. I have the same problem whether the screen saver is on or not. Moving the mouse does not change the black screen. Thanks.
dell latitude d600 screen stays black when I turn computer on.
Probably had a black screensaver
does the screen go blank immediately after bootup to your operating system ?
Robert
Does computer come on at all, does it boot up then goe blank? Sounds like possible ram problems, motherboard, or CPU. Does fan come on to cool machine?
