I log in to messenger it opens but then it shuts down the window to messenger.
    Brigadier General:
  • 5,158 Answers
Quick fix would be to reinstall messenger
Robert
Posted on Aug 28, 2008
I want to open two accounts of yahoo messenger at the same time..i need two ym windows to log in..how can i have multiple window of yahoo messenger if my OS is windows 7?
I'm not sure if Yahoo messenger has the specific ability to log in to two accounts simultaniously. If you don't mind using another client to log into your Yahoo account, there are a lot of third party messaging clients (Trillian, Pidgin, Spark, Meebo, etc) that will let you log into multiple accounts at once. These will also let you sign into other protocols such as AOL IM, MSN messenger, ICQ, IRC, Yahoo IM, and several others.
If you're open to trying a new client, I'd recommend trying Pidgin: http://www.pidgin.im/download/
Its probably one of the easier clients to learn to use.
If installing new software is an issue, use one instance of Yahoo Messenger and a web client like https://imo.im/
Please leave feedback if this was helpful. Thanks.
Apr 16, 2011 | Yahoo Messenger
Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, ...
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Mar 11, 2011 | Computers & Internet
How do I stop yahoo messenger
Hi , when you enter your username and password in yahoo messenger , you are logged in. To log out of the yahoo messenger, click on messenger, which is in left top side of yahoo messenger . when the drop down open's, click on sign out. Now you are logged out of the yahoo messenger.
Feb 13, 2011 | Yahoo Messenger
Not getting to open mail or on to the messenger service
try logging off & logging back on. If that doesn't work shut your computer down & power it back up & then log back on. Bet it works.
Mar 11, 2010 | Yahoo Mail
Instant Messaging shut down when I want to send. I upgraded to the latest version of WLM. I open it, I open an instant messaging window, I type my message and when I hit the return button to send, it shuts...
First see if there is any firewall blocking WLM, you can check that from the settings of the firewall that you are using, like Windows Firewall or Zone Alarm. If so change the setting.
If not, check is any other messenger services are having the same issue. You can check it with yahoo messenger or skype.
The final and best option would be to uninstall the old WLM completely from the computer and reinstalling it from the internet.
Good Luck
Sep 19, 2009 | Microsoft Windows Live Messanger
Webcam doesn't work on MSN Messenger but works fine on Yahoo
I have a Dell XPS M1330 with integrated webcam. Suddenly the webcam cannot be opened by Windows Live Messenger, have tried uninstalling windows messenger and re-installing and didn't work. and a cat keeps caming up
Jul 15, 2009 | Acer Aspire 5610-4648 Notebook
All my contacts are missing from my contact list
This is what MS told me to do..but did not work. Finally they told me to use 8.5. Try if it helps you.
Messenger Connectivity Log & Contacts Log
A. Delete the old log files.
Right-click the Start button and then click Explore. In the window that opens, click Folder Options on the Tools menu. Click the View tab, and then make sure that Show Hidden files and folders option is selected.
1. Click Start, click Run, type %userprofile%\Local Settings\, and then click OK.
2. Double-click the Application Data folder, double-click Microsoft, and then double-click Messenger.
3. In the Messenger folder, look for the MsnMsgr.txt file and delete it.
Note: If you get an error stating that you cannot delete MsnMsgr, please make sure that Windows Live Messenger is not running on the background. To check this, open the Task Manager window and check whether the msnmsgr.exe is running on Processes. If it is, select the application and click End Process. If you are prompted, click Yes.
To open the Task Manager: Click Start and then Run. Type taskmgr.exe and click OK.
4. If you don't see the MsnMsgr.txt file, please proceed to step B to enable the connection logging.
B. Turn on connection logging if the feature is not yet enabled.
1. Start Windows Live Messenger but do not sign in.
2. On the Tools menu, click Options.
3. In the left navigation bar, click Connection.
4. Click Advanced Settings.
5. Under Connection Logging, make sure that the Save a log of my server connections to help troubleshoot connection problems check box is selected.
6. Click OK.
C. Try to sign in to Windows Live Messenger again to replicate the error or issue being encountered with the service. A new connectivity log file, MSNMsgr.txt, is created the moment a sign in attempt to the service is made. When errors or issues are encountered, the connection logging feature will capture their logs.
D. Access the newly generated MsnMSgr.txt by following the steps in step A. Please look also for the ContactsLog.txt file. Please attach the files on your e-mail response to us.
Copy of the Windows Live Contacts folder
The Windows Live Contacts folder can be accessed on this path:
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts
Note: Windows Logon name is the logon name that you use to sign in to Windows.
Right-click the Windows Live Contacts, select Send To, and then select Compressed (zipped) Folder. A compressed file is created in the same folder. Please upload the file to Windows Live SkyDrive and we will retrieve the file from there.
To access Windows Live SkyDrive, please do these:
  1. Open your Internet browser and visit http://skydrive.live.com.
  2. Sign in using your Messenger ID and password.
  3. Click on the Public folder.
  4. Click Add files and locate the zipped Windows Live Contacts folder. Upload it.
  5. Once the file is successfully uploaded, please send us the URL or link on your e-mail response so we can download it.
While we are working on this issue, we suggest that you temporarily use the earlier version of Windows Live Messenger (v8.5) so you can continue to communicate with your friends. Please note that to be able to install the previous version, you need to uninstall all the Windows Live Essentials programs (i.e. version 2009 of Messenger, Mail, Photo Gallery, etc.).
1. Exit Windows Live Messenger.
2. Click Start, click Run, type appwiz.cpl and press Enter
3. On the Add or Remove Programs window, click on Windows Live Essentials, and then click Uninstall/Change
4. Select Uninstall, click Continue.
5. Under Select the programs you want to uninstall, check all the Windows Live programs shown and then click Continue.
Windows Live Messenger 8.5 can be downloaded from:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
Apr 29, 2009 | Microsoft Windows Live Messanger
Every time I log into yahoo messenger I get booted off shuts down
it's beacuse of the firewall settings that the Norton program has by default, try changing them.
also
it can be for 2 reasons 1.Lines are busy at that time. 2.You have an other yahoo messenger (eg Yah mes beta) so you should deactivate 1 of them
Nov 20, 2008 | Computers & Internet
Hi, I am a Messenger user with L plates from downunder! What I would like to know is how I can get Messenger to sit in my system tray when I start up my laptop, so that I can then simply log in and be...
first question: Click Start, then right click windows live (messenger)>
then, select Send to> then select again Desktop (create shortcut)>
then u can now simply log in quickly less time in your messenger. coz u just click the shortcut pin on your desktop.
2nd question: invite your friends whoever you'd like to converse with a group. invite them to join conference or simply click there on your IM box invite someone to this conveation> then u and your friends the other one can talk in just on IM box.
Hope it help u. :)
Aug 14, 2008 | Computers & Internet
MSN Windows messenger shuts pc down
Pls. Try scanning your hardisk.
Start ->Run ->"CHKDSK" ->ENTER
Aug 05, 2008 | Microsoft MSN Messenger Connect for...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
