Question about Car Audio & Video
Kenwood kac 818 amp
I have a kenwood 818 amp. one day i changed the one of the fuses and turned it back on. where i had put the fuse in, it started to smoke a lil bit. and my subs made a awfull noise. since then i havent been able to get it to turn on. where tha fue goes in its burnt a lil bit. i really like ths amp and the power it gives. so i hope ull be able to help. thnk you
I had the same problem the fuse i used was the same amperage but the plastic was a very poor grae and it actually caught on fire so i went to the auto supply and bought a higher grade fuze and havnt had a problem since good luck
Posted on Aug 30, 2008
My kenwood excelon x1200m amp turned off randomly and will not turn back on
You may have blown a fuse. There should be one on the amp itself and the other is generally installed on the main 12V power cable. Most installers put it in the engine compartment for easy access. Pull each fuse and make sure it's still intact. If not you'll need to replace it. Most auto parts stores will carry the fuse, just take the old one in to make sure you get the correct amperage.
May 02, 2011 | Kenwood eXcelon X1200M Car Amp
Blows the 30 amp fuses
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | Kenwood KAC-9102D Car Audio Amplifier
Fuse blew on my lanzar amp and now it won't turn on.
that my find is some am trying to figure out
you say you turn of deck and fuse blow that dont make sense .look at it again
Apr 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC 7202 amp not powering on
First you should test to be sure the amps main power feed is supplying 12+ volts to the amp. and that the other connections (head unit remote lead - input & output signal leads) are properly secured, if all is well then there maybe an internal issue with the amp.
It is not recommended to affix an amp directly to a speaker/kicker box, hence the vibration that may cause wire connections and/or internal electronic components to become loose or faulty.
As far as "should i take the amp apart and look at its guts"
NO, sorry but given the way you phrased your question I can assume that your electronic troubleshooting knowledge is not up to par, and that task would be a waste of your time.
Good luck
Aduz
Mar 26, 2009 | Kenwood KAC-7202 Car Audio Amplifier
My 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
Plz Help - unknow problem
Sounds like a short circut protection on the amp kicking in. It sences the power going to the drivers and cuts itself out before damage is inflicted on the subs.
Mar 18, 2007 | Kenwood KAC-7252 Car Audio Amplifier
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
