Question about Sharp R-1610 Microwave Oven
R1610 microwave the panel that is over the door is broken and i would like to order a new one and cannot finfd the description of it
  • 100 Answers
It's called a vent louver. You'll need the exact model # from inside the microwave when inquiring to get the correct color.
Check with www.microwaveglasstrays.com or call them toll free @ 1-877-894-0035 to order. (I think they're somewhere in the $35 range.
Posted on Sep 06, 2008
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order parts here if needed.
May 26, 2010 | Frigidaire Microwave Microwave Oven
The door handle is broken on model khms 105ebl0 kitchenaid
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 04, 2009 | KitchenAid KHMS147 Microwave Oven
Broken door on my Emerson microwave (MW8985W)
You can order the outer panel. Its available at searspartsdirect.com for about $41. Just type in your model number and look under the "Door Assy" heading. To replace, just follow these steps:
You have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and any screws that may be holding the outer panel in place. Some panels are simply snapped in place.
Remove the broken panel and install the new one. Re-install the door handle and re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Aug 27, 2009 | Emerson MW8985W Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
A broken handle on door&how to fix it
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
1990 Sharp Carousel II over microwave / vent hood
Sharp calls that the turntable coupler when it's a separate part.
If it's part of the the part with three legs, that is called the turntable support.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If yours is model R1610, we actually have that full service manual on our site at http://www.microwavedisplay.com/r1610_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 02, 2008 | Sharp R-1610 Microwave Oven
Sharp r-1610 microwave
It could be the turntable motor, the turntable support (with built-in coupler) or a problem on the control board. I would first look at the 3-legged turntable support with built-in coupler to see if it got hot and warped. It should be flat across the top from the center to the end of the legs. If the support's legs are pointing a bit downward, it will prevent the coupler from making contact with the motor shaft. I've held bent ones a few inches over a gas burner to heat them up where the legs meet the center hub, then set something a bit heavy on it to hold it in place while it cools. If it needs a new one, it is part # FROLPB025MRK0 and it runs $19.50 retail at Tritronics. A quick (but not necessarily definitive) test of the motor is to grab the shaft gently with pliers and gently try to turn it. If it moves slowly and makes a high-pitched whining noise, it's likely okay. If it won't turn or grinds, it is bad. The number for the new turntable motor is RMOTDA264WRZZ and it retails for $8.87. Please note that you may need to look under model R1600, R1600, R1601, R1601, R1610, or R1612. They are all mostly the same. Tritronics is at http://www.wehaveparts.com The service manual for the R1610, R1611, R1612 can be downloaded at: http://www.microwavedisplay.com/R1610.pdf There may be a grommet bewteen the mtoro and turntable support. Don't lose that! Be safe!
Dec 03, 2006 | Sharp R-1610 Microwave Oven
Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Nov 15, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1610 Microwave Oven Logo
57 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
