Question about Canon PIXMA MP780 All-In-One InkJet Printer
Print head on Canon Pixma 780 doesn't move
LED says Check Printer press [OK]
  • Anonymous Sep 05, 2008
    cartridge jammed
    check printer
    papar jammed
    error #356
  • Anonymous Dec 16, 2008
    I have the same problem as well. If anyone has a solution, great!
Display printer says chec printer ##357
Posted on Jan 15, 2009
I have a canon pixma 780. I hardly ever use colour yet the colour cartridges keep running out.
Every time you turn on your printer, it goes through a print head cleaning routine and the print head nozzles flush all the inks into the cleaning pads. This is why the inks are levels are dropping even though you have not printed anything.
Nov 02, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I HAVE CANON PIXMA 780 AND I GOT THE FOLLOWING ERROR: SERVICE ERROR 6A00. HELP ME PLEASE. THANKS. ALCIDES FROM COSTA RICA
Error 6A00 is a problem with the sheet feed unit. Manually moved the print head left and right, turn the printer on/off should do the trick.
Make sure to blew some compressed air around to clear any foriegn objects.
Hope this information will be helpful. Thank you for using Fixya.
Apr 12, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Alarm button flashes, check printer, press OK .Error 6A00 appears, Pixma MP 750
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 14, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
Prints every other line
Use the cleaning cycle first.If it completes do a nozzle check and then to align follow below.
You need to hook it up to computer to do a manual head align through the printer properties maintenance section.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer pixma 780
Press MENU SCAN COPY than SCAN
Cycle throught options until #7 PRINTER
Pres OK
Cycle throught options untill #5 INK ABS CAP
Press OK
Display SUCTION
Enter 0
Press OK
Turn Printer off
Pause
Turn Printer back on
Feb 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
496 people viewed this question
old marine
old marine
