Question about Brother Office Equipment & Supplies
I have a Brother MFC7820N. The copies are terrible. I cleaned the corona wire. My question is, how do I clean/refurbish the drum?
I fixed the problem myself. When I looked carefully at the drum assembly (Brother part DR350) I figured out how to remove the top cover. So I put on some gloves and, after buying a box of alcohol wipes, I sat at the kitchen table FOREVER trying to remove a retaining pin. It really wasn't that hard, it was mostly due to my inexperience and the fact that I'm female with not much hand strength.
The drum was covered with stuck on toner. The plastic assembly and the drum were both easily cleaned by alcohol wipes, compressed air, and Rags-in-the-Box (a thick, mostly lint-free cloth). I strongly recommend going outside to use compressed air to clean out the vents/fins ... you will see toner shooting out in a fine mist EVERYWHERE.
Once everything was clean I reassembled it but found I could only put it together with the gears on the opposite side of where they were originally. I knew that wasn't how I'd found it but let it go and tried printing. Everything went well for about 4 copies then every page jammed - I don't know why the first ones went through without a hitch.
Boy is there a difference between doing something once vs. not having any experience! This time I knew I didn't have to remove the retaining pin before I lifted off the top piece and exposed the drum. Life is much easier if you wait to take off the retaining thingy after you remove the top. Disassembly and reassembly went much faster the second time. Now I could probably do it in less than 15 minutes flat.
TIP: to remove the top you place the drum assembly flat in front of you with the back of the assembly facing you. Then gently rock the top piece toward you and lift up and out.
TIP: wear gloves (nitrile or latex-free work well) and NEVER touch the drum with your fingers.
TIP: When you remove the axle rod (long thin piece of metal which runs through drum) there are two thin strips of metal which narrow and don't allow the rod to be put back through unless separated.
I was worried the alcohol might damage the coating on the surface of the drum so I wiped it with a lint-free cloth as soon as possible. It seemed to work out okay. I've printed over a hundred copies in pretty short order since I put the machine back together and the print quality is just as good as new.
FYI: when I first powered up the printer, there was a smell I attributed to alcohol being burned off. I was concerned I might have created a fire hazard (not a good thing) and seriously considered chucking the whole drum assembly. If I had to do it again, I'd make certain to rub the alcohol off the drum faster. In the end, the smell burned off very quickly.
Posted on Aug 30, 2008
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Jul 23, 2014 | Brother MFC 7840W Printer
Does the Brother MFC-440 CN have a roller or drum? We are getting lines on our copies when we copy by inputting the papers in the feed tray.
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
Feb 25, 2011 | Brother MFC 420CN All-In-One InkJet...
My Brother MFC5440CN when copying the copies come out with a black line down the middle can anyone help
Jan 26, 2011 | Brother MFC-5440 Printer
Printer says drum error see trouble shooting and maintenence care in manual. I have replace toner and drum
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Oct 27, 2010 | Brother Tn650 AllInOne Laser Printer
Drum Error on Brother MFC 7840W
Has two situations:
  1. The corona wire on the drum unit needs to be cleaned.Clean the corona wire on the drum unit.
  2. The drum unit has reached the end of its life. Replace the drum unit.
Feb 15, 2010 | Brother MFC 7840W Printer
Changed the toner now I am getting black copies?
It's important to gently shake toner cartridge from side to side to distribute the toner. It's also important to clean the corona wire (by sliding the tab from side to side) and the drum each time you change the toner cartridge. You should remove the toner cartridge (be careful, it can be messy), clean the corona wire and drum and your copies should return to normal.
Dec 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
How do i clean carona wire
For a photocopier to work, a field of positive charges must be generated on the surface of both the drum and the copy paper. These tasks are accomplished by the corona wires. These wires are subjected to a high voltage, which they subsequently transfer to the drum and paper in the form of static electricity.
Visit the following website and your question will be answered...
http://www.retrevo.com/r/23303dj198/180/Cleaning+the+corona+wire/
Nov 08, 2009 | Brother MFC 7840W Printer
Same problem even with new Brother drum
Did you replace the drum or the toner cart? The drum has a blue lever that you slide back and forth around 20 times to clean the corona wire. I sometimes use a cotton swab with alcohol to gently clean this wire as well.
Jun 23, 2009 | Brother MFC 8500 All-In-One Laser Printer
Cleaning the drum unit corona
Message is telling me that the drum is dusty. It says to clean the corona with the wire. I don't know what the corona is and I cannot find a wire that might help me know how to clean the corona
Aug 18, 2008 | Brother Office Equipment & Supplies
Pls Clean Drum
The drum is the larger plastic unit that slides out an the toner cartridge fits into it. The corona wire is the very fine wire at the front top of the drum. Just slide the little cleaning tab back and forth.
Aug 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
151 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
