Question about E-Machines eMachines Desktop PC
Usb ports not working
Everything is enabled and the computer says the device is working properly and i all ready tried letting windows reinstalling the correct driver, but still i get nothing when i plug in a junk drive ( it works on other computers so i know it's not the junk drive.) please help
  • alex_b15 Sep 04, 2008
    bios is enabled and so is plug and play. but still no junk drive pops up or even recognized.
  • babcia_62 Sep 11, 2008
    I looked in services and plug and play is set at automatic and Universal is set to manual. Still my PC does not recognize the 3 USB ports on the front of my tower.
  • E-Machines Master
  • 3,051 Answers
Have you booted into bios and looked to see if the usb ports are enabled and that the plug and play is enabled please try that and get back with me ok best regards mike
Posted on Aug 29, 2008
  • Michael Thomas
    Michael Thomas Feb 14, 2009
    also under device manager if the host controller driver is installed you will see the usb symboles there if it is not showing the usb symboles than u will have to install the driver under control panel add new hardware and add the controler from there ok
  • Michael Thomas
    Michael Thomas Feb 17, 2009
    Hi there again
    I was wanting to get back with you to see if the problem had been corrected or is it still occuring
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Usb ports do not work. Windows does not recognize them.
IT may be time for a new systemboard. This is a common recall issue with the dV6000. If you wanted to be sure, you could reinstall windows just to verify everything is okay there.
Jan 06, 2011 | HP Pavilion dv6000 Motherboard
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
Oct 16, 2009 | Dell Inspiron XPS M140 Notebook
Usb ports
This can only mean on thing that the USB port on your computer is not properly working, what you can do here first is to run the setup CD for your motherboard so all the software including the driver for the USB port will be reinstall, if after that still not working the USB port of the computer is already bad...
May 27, 2009 | Computers & Internet
2 of 4 USB Ports Not Functioning
Most likely a motherboard problem, though you can try and re-do windows, best bet on getting it all to work is Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Though this might really get on your nerves having to do this multiple times, id get a new motherboard.
Dec 26, 2008 | Gateway 4540GZ Notebook
Hp 2015d will not print. Everything is on and the driver is installed. We have also tried to reset printer. Powered it down.
Hi Tmthymngn,
When printer is ready. Press the Green button. A Demo page will be printed. If this works, try to connect printer to a different USB port on the computer. Computer should detect that you have a usb connected. Or connect a USB drive to the port instead. If the drive is not detected, the USB port might not have been activated. On your computer, click Start|Settings and select Control Panel. In control panel, double click on System, then select Hardware tab. Click on Device Manager button. In Device Manager window, look for Universal Serial Bus Controllers. Click on the + sign. Right Click on each host controller tand select properties to see if each is enabled and working properly. If it is disabled, enable it.
Rgds
S88
Dec 18, 2008 | Office Equipment & Supplies
Usb port issues
You could try uninstalling the USB items in Device Manager and allow them to be reinstalled. Also verify USB is enabled in the BIOS.
Dec 06, 2008 | Acer Aspire 5580 Notebook
USB ports suddenly not functioning
hi, see if you have installed any new devices/hardware to see if its conflicting, often grafics cards conflict usb devices, also just check that in the setup(when you boot up)that the usb ports have not been disabled or usb keyboard support hasn't been enabled/disabled. good luck!!
Apr 01, 2008 | EliteGroup nForce3-A Motherboard
E-Machines eMachines Desktop PC Logo
83 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
