Question about Pentax *ist DL Digital Camera
Can *ist DL do High-Speed/Wireless Flash?
I've been reading the *ist DL manual and according to it the *ist DL WILL do high-speed flash sync and also wireless flash with an external flashgun, just like the *ist DS. Can anyone confirm that this is correct from a different source? The manual I am using is the istDL_web.pdf manual from the http://www.pentaximaging.com website; last modified on the 13th of June 2005. http://www.pentaximaging.com/files/manual/istDL_web.pdf My local camera shop which had previously told me that they had stopped stocking Pentax DSLRs got the *ist DL in last week (Pentax must be offering it at a decent price to the retailer) so I may have take my flashes in and test it if no one else can confirm (that’s if they’ll let me test it).
  • Anonymous Mar 28, 2014
    how to assemble / disassemble a Pentax Ist D
    Master:
  • 542 Answers
I suspect that it is virtually identical in capability to the DS model with respect to flash capabilities. Someone with a DL and an AF360FGZ flash unit will be the only ones who can verify for sure. Neither Phil Askey nor any of the other review websites are guaranteed to be correct. Not even manufacturers' manuals are guaranteed to be correct.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
According to the manual (page 153), the DL DOES support P-TTL flash, with the built-in or external flash, but only supports high-speed flash with an external flash. What I'm wondering is, what is high-speed sync flash useful for? The only thing I can think of is fill-flash outdoors.
Black line from bottom to half way up camera which gets higher as i increase shutter speed
Chances are you're using too high a shutter speed. Here's a link to understanding how that works. Good luck!
High Speed Sync Flash
Jan 09, 2013 | Canon EOS-AE-1 35mm SLR Camera
High speed sync
What about High Speed sync? Just saying High Speed sync you cannot expect anyone to assist you.
Aug 18, 2010 | Nikon Speedlight SB-800 TTL Flash
Flash fires but the image is dark. Tried the flash on two Canon cameras, same problem with both.
Check the flash sync speed on the cameras. With most film cameras, the flash sync speed is 1/60 of a second.
With digital cameras, you must use a flash rated for the digital camera and use their recommended flash speed.
If the camera to flash sync speed is correct it is possible that the flash output is weak. This would be due to the battery not being able to properly supply, or some defective components in the flash circuits.
You will require a flash sync detector, a flash intensity meter, and a battery load tester to perform the the first level of basic tests if you wish to analyse the fault yourself.
This is not a problem you could service yourself, unless you are experienced and knowledgeable for servicing flashes.
These flash units use very high voltage at a very high current when operating. The current is built up and stored in a very efficient high voltage capacitor. A flash can be dangerous to service yourself.
Jerry G.
Sep 25, 2009 | Canon Speedlite 220EX TTL Flash
Black area in photograph
Unless you are using high-end Nikon Speedlights with camera and flash set for Auto FP High-Speed Sync, your top flash sync shutter speed on the D80 is 1/200 second. The black band you are seeing at faster shutter speeds is because the second curtain of the shutter begins to close before the first curtain reaches the fully-open position (which is when the flash fires). The higher the shutter speed, the shorter the gap between first and second curtains. To get full exposure with flash, there must be an instant when the shutter is fully open -- first curtain completed travel, second curtain not started yet.
"As the speed increases the final image should get lighter" applies to ISO speed. Higher shutter speeds mean less light reaching the sensor, but that's not the cause of the black bands.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
    u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
    Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
    Flash won't work
    Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
    Jan 08, 2007 | Pentax *ist DL Digital Camera
    Why is my *ist DS eating my SD cards?!
    I've used Sandisk Ultra II 512M cards, a PQI 1G and a Transcend 1G card (all high speed rated) in the *istDS. I've done about 1500 exposures now, many RAW, and have done several rounds of upload to my computer. No problems at all. These same cards work flawlessly in a Panasonic FZ10 as well. Either you have had a bit of bad luck, two defective SD cards in a row, or have a *istDS with a stuck or bad memory card controller. Try using the Reset command in the Set Up Menu, see if that helps. BTW, always format SD cards with the camera once before you start using them.
    Sep 13, 2005 | Pentax *ist DS Digital Camera
    Flash on ist DL
    Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
    Sep 08, 2005 | Pentax *ist DL Digital Camera
    Pentax *ist DL Digital Camera Logo
    137 people viewed this question
    Top Pentax Cameras Experts
    Geoff Hone
    Jerry Greenberg
    Jerry Greenberg
    Mohamed Ismail
    Mohamed Ismail
    Are you a Pentax Camera Expert? Answer questions, earn points and help others
