Question about Lexmark X4270 All-In-One InkJet Printer
Envelopes my printer prints everything except envelopes. The address is barely readable. Thanks.
    Genius:
  • 2,035 Answers
  1. Click Start, Settings, Printers and right click on the Lexmark printer. (If you are using XP and cannot find the Printers folder, right click on the Start button and select Properties. Select Classic View and then OK.)
  2. Select Properties from the menu that pops up. (If you are using XP, select Printing Preferences.)
  3. Click the Document Quality tab and select black only on this screen.
  4. Click on Apply and then OK.
Try to make a print....
Posted on Aug 29, 2008
Ink spots on envelopes
Hi rebecca,
Go To Below official Hp Printer Forum Page For Your problem And Solve Your Problem Black ink stains envelopes when printing HP Support Forum 955951
Feb 24, 2014 | Canon PIXMA MX340 Wireless Office...
How to print envelopes
1.Buy envelopes at any office supply store. They come in all shapes, sizes, textures and colors, so choose ones that go with the type of invitation you are sending out.
2.Open Microsoft Word 2007 and click on the Mailings tab.
3.Click on Envelopes in the Create section.
4.Click on the Envelopes tab when the Envelopes and Labels box comes up. The box will probably come up with the Envelopes tab open, so you may not need to do this.
5.Enter the recipient's address in the Delivery Address box. Invitation envelopes should include the names of everyone invited--for example: Mr. and Mrs. Smith, Mrs. Smith and family. Don't worry about the font at this point--you can change it later.
6.Enter your return address in the Return Address box. As with the Delivery Address, you can change the font later.
7.Click on Options. Use the drop-down menu in the Envelope Options tab to change the size of the envelope if needed. The packaging of the envelopes that you purchased will have information about the size of the envelopes. It is very important that you choose the correct size so that the envelopes print correctly.
8.Adjust the font of the delivery and return addresses. Click on Font in each section and change the font style or size. You can also bold, italicize or choose other options regarding the font.
9.Adjust the placement of the delivery and return addresses on the envelopes. In each section, click the arrows in the "From left" or "From top" boxes. In the preview section below, you can see the movement of the addresses as you adjust the placement. Line up everything so that it looks good to you.
10.Click on the Printing Options tab. This is important because you must select how you feed the envelopes into your printer. Choose the correct way that they are fed, whether they are fed into the printer face up or face down, and if they should be fed in manually. This will all depend on your specific printer. Consult your owner's manual for this information if you are unsure. Click OK and you will return to the Envelopes and Labels box.
11.Insert the envelopes into your printer. Click Print once you have everything formatted and arranged how you want. You should print one envelope first to make sure the layout is correct. Once you've confirmed it printed correctly, print all your envelopes.
Sep 21, 2011 | Canon imageRUNNER 1023 Black and White...
How to print the envelopes on samsung laser printer CLP-310
Try printing address on envelope with MS Word as it has the facility under Tools/Envelopess where it will store the 'from address'
Both addresses are fully ajustable ie. left or right, up or down - no doubt there are other programmes for your purpose.
Thanks
I usually print the 'from' address in the top left hand corner on the
DL sized envelopes
Jan 30, 2010 | Office Equipment & Supplies
My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
May 17, 2009 | Lexmark X2600 InkJet Printer
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
How to address an envelope?
Use Microsoft Word's envelope address feature (or Open Office).
Feb 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
PRINT IS BARELY READABLE
There are two levers at the top of the fuser that have envelope icons on them. These levers reduce the pressure on the fuser assembly for thick stock.   If you leave them in envelope mode and run thin stock there is inadequate pressure on the fuser rollers to press the toner onto the paper.  Hence a lighter output.  I found this problem at one of my current client locations.  Hopefully this helps.
Jul 06, 2008 | Konica Minolta magicolor 2400 Laser...
My printer is now printing very small letters, barely readable
The solution is to change the resolution of printing y setup page of you printer I have a canon bjc-1000 it has a 90x90 DPI resolution, thats why printed like a miniature, but I change the resolution to 180x180 DPI and... ta da! printing is 100% scaled and everything gonna be alrigth. I hope it is useful for somebody.
Regards,
Wilson Crespo
May 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Envelope prints the wrong way
Just choose "landscape' from the printer properties instead of the default 'portrait'. Now adjust the margins, etc so that you can position the text exactly whre you want it
PS. Dont forget to rate this Fixya if the solution worked!
Cheers!
Irish Druid
May 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
