Question about Pentax *ist DS Digital Camera
DS Exposure Question
After my first 1000 pictures I'm beginning to adjust to how my DS "thinks". By now I've decided to use centered spot focus only for more control, occasionally like & use the comfort of the Auto ISO feature, and I'm pretty comfortable with both auto and manual focusing. What still puzzles me is the way the DS exposes. I've read a lot of threads here in this group and have seen that "underexposure" of the D/DS has been subject of several heated debates. I don't want to start this off again, but by now and after checking out several lenses - among them my very newly acquired Pentax DA 16-45 - I think that I have a very often a very pronounced underexposure with the DS; the histogramm pretty consistently doesn't reach into the right quarter of the scale, and importing the images into Photoshop CS (I only shoot in RAW) I have to adjust exposure also very often for one full EV. That doesn't help image quality. And this is not only happening in high contrast situations. As I said I don't want to do another round of "underexposure discussion". My question simply is: Do I have a faulty DS at hand which I should have checked for readjustment of its exposure measurement system? Or is this behaviour - especially this routinely "exposing to the left" leaving the right quarter of the histogramm empty - not a bug but a feature of the DS? I'd hate to send the camera in and to get it back four weeks later with nothing changed ... I could live with an permanent exposure compensation setting (and have the occasionally overexposed pic then), but surely would miss the Auto ISO feature which is locked if one uses the compensation. So it boils down to: Send it in - or live with it?
    Master:
  • 542 Answers
I believe I see the problem: "0 exposure compensation". Based on the scene I would have compensated to +1 EV (diffuse light/thin clouds) or even +1.5 (sunny/clear sky). And I would have used M mode and center-weighted metering or gray card and spot metering. Now the logic behind the scenes and the procedure: 1) Camera sets Av/Tv to produce MID-GRAY exposure (is it 18% or something else is irrelevant here, one will need to "feel" what camera assumes to be mid-gray). 2) Parameters established should be used just as a *starting point*. It is up to a photographer to compensate exposure and "brighten" scene if it is brighter than mid-gray, or "darken" the scene if it is darker than mid-gray. That's why we have exposure compensation. Examples with approximate values based on my experience (assuming Av mode is used so camera sets Tv only): A) Winter scene, snow, around noon, clear sky - camera sets 1/1000 - I compensate to 1/250 B) Beach scene, light-gray sand, bright sunny day: - camera sets 1/500 - compensate to 1/250 C) City streets, clear sky or light clouds (hint: lots of concrete and asphalt, already gray!) - camera sets 1/125 - no correction D) Cloudy day, murky weather: - camera sets 1/30 - compensate to 1/60 E) Night scene (bar or a street) with no bright lighting: - camera sets 1/8 - compensate to 1/30 Without compensation examples A and B would produce boring "cloudy looking" winter scene pictures and D and E in brighter than normal with all bright surfaces or well lit areas totally overexposed (especially E). We can practice this at home: we have everything from bright lamps, white walls to "gray" floors to dark corners and black sofas and recliners. Switch to center weighted, point, think, compensate then press shutter release. It was not easy but I got it eventually got it. (With K1000 was actually easier since you have analog light meter, MX was quite a shock to me with LEDs, now DS is showing only numbers... believe it or not I would pay $$$ for K1000-style reading in DS
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I suggest you get your camera checked. You are seeing the same problem I've observed with two different DS bodies. My son and I call it the "sunglasses effect" -- it makes me feel like I am looking at my computer monitor while wearing sunglasses. The easiest way I found to test was to compare side-by-side with another Pentax DS. I took it back to the store (the dealer has been VERY helpful) and we compared how my DS, the store's demo DS, and a Rebel XT metered the same scenes. My DS was consistently a stop or more below the other two cameras, while the demo DS and the XT were basically in agreement. The symptoms I saw were as you describe: noticeably underexposed pictures for no apparent reason. I would often get photos with virtually no data on the right half of the histogram (even when looking at individual color channels), which is just not right. (Just as an aside, my results were *not* the type of underexposure that RiceHigh seems to be reporting, with lens variations and 1/3 stop stuff -- it was really bad and consistent across all lenses.) I ended up using the faulty bodies with +1.0 EV permanently dialed in, except that didn't work well when I used my old Pentax flash. Anyway, after the dealer tried it, he insisted I exchange it. I did, and it was like night and day (yes, pun intended :-) ). The replacement body metered much better (it had other problems, so had to go back as well, but that's another story...). I am sensing a repeated theme here, but I don't know what to make of it. Faulty calibration equipment in the factory for one of the assembly lines? I dunno....
    Master:
  • 542 Answers
I haven't found any underexposure problems with my DS. The only "underexposure-thing" I found is that when it's sun reflections within the image (from water, cars with metallic paint and other highly reflective surfaces) the camera will underexpose to avoid blowing out the highlights. In complex lighting situations with many dark and bright areas, it will expose to retain texture in the shadows but still without burning out the highlights. The only image-processingt that I sometimes needs to do, is to lift up the midtones. The darker tones and the bright tones are in most caes exposed just the way I would do it myself if I was a camera, but the midtones can be off. Now, this is not a fault in the camera - it's an effect of the limited dynamic range that digital has in comparision with film. Lighten up the midtones without affecting exposure of dark and bright areas, is image processing and has nothing to do with exposure settings.
I am having a problem with my new Pentax DA 50-135mm 2.8 lens not focusing
Hi Ally,
It sounds like you may have commanded the camera to use one of the other 10 focus points in the viewfinder. There are 11, total with one in the very center, and the rest around it. It looks like this:
Page 130 of the manual begins a discussion of Auto Focus. Page 133 details how to change the focus point. If you like to center the subject in your veiw finder & pictures, you should select the center focus point if it is set to one of the others. You may still have dark or soft pictures if the shutter needs to stay open too long. You can reduce the exposure time by bumping up the ISO to a value of 400 or 800 or more - as limited by you liking. The higher your ISO goes, the less time required - but the more grainy the image is.
Jan 28, 2012 | Pentax SMCP-DA 50-135mm f/2.8 Lens for
Washed out pictures
set auto and take pics if pics are washed out adn dis colored and streaked then
CCD failure !
call Pentax i think they will do it free of charge it is a known problem in thousands of cameras just give them a call
http://www.pentaximaging.com/support/
Mar 22, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Blurry Pictures
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. If the camera can automatically set the focus and exposure, the LED by the viewfinder will turn GREEN. If the camera can not adjust the settings automatically, the LED will turn RED. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE (Flower Icon) for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Using MACRO MODE improperly will result in poor focus. 4. Rely on the Rear LCD Display. When in doubt, trust the LCD. The LCD will display the subject more accurately than the viewfinder. This will help with "framing" the subject, or determining if you have enough light for proper exposure. 5. Motion can cause a "blur" effect. Either motion of the subject, or motion by the photographer. This phenomenon is just like traditional photography. Moving objects may appear to blur, and this will be even more evident in lower lighting situations as the shutter speed slows down to allow for more light. The shutter will react faster in bright light, and motion will not be as apparent.
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Blurry Pictures
Sep 15, 2005 | Toshiba PDR-M25 Digital Camera
Better Focus
There are several factors that can contribute to getting better focus and improved results. 1. Auto Focus / Auto Exposure lock. Press the shutter button down HALF WAY. The camera will attempt to adjust exposure to the current lighting environment for maximum benefit. Then the camera will automatically correct the focus based on objects in the center of the display. This process usually takes about two to three seconds. 2. Be sure not to cover the sensor on the front of the camera with your finger. This will disable the automatic focus and exposure controls. 3. Only us the MACRO MODE for CLOSE-UP photography. Be sure to use MACRO MODE if you are taking pictures of an object at less than six inches away. Be sure not to use Macro Mode for Normal Photography. Using MACRO MODE improperly will result in poor focus (also known as 'fuzzy pictures').
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Blurry Pictures
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Difference between Auto Picture/Program Mode
Auto Picture-selects on of the picture mode such as landscape(mountain), macro(flower), sport/action(running man) mode, etc. P-sets shutter and aperture. You set everything else. happy face- sets shutter, aperture and everything else.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Landscape picture
You don't normally want to focus on infinity for landscape shots. Auto focus on mid distance between you and infinity [horizon or most distant object] while half holding down shutter button re compose your pic and shoot. Depth of field will help to ensure that everything is in focus larger F stop more depth of field. f2.8 minimum depth of field. This is digital, film is cheap :-) Using the same focus spot, take one shot at each aperture and decide which aperture gives the desired results in terms of sharpness, I think you will find that will be around f4. Then try different focusing spot [closer or further away] to adjust how much between you and infinity is in focus depending on the results YOU wish to achieve.
Sep 06, 2005 | Panasonic Lumix DMC-FZ2 Digital Camera
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Pentax *ist DS Digital Camera Logo
165 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
