Question about Minolta Office Equipment & Supplies
We have a Minolta DI250 and when we copy a document comes ot blank in the middle of the paper. Does anybody knows what could be the problem?
    Sergeant:
    Champion:
  • 307 Answers
Blank in middle could be lack of toner or developer in the developer unit. Also bad charge or transfer coronas. Is paper
wrinkled? You might make a copy and stop the copier before thapaer goes into the fuser, and see what kind of copy on the paper. If complete problem is in the fuser such as warped rollers, etc.....
Posted on Aug 28, 2008
Printer producing dirty copies
it could be that the roller needs cleaning, how you do that, I don't know, but that's my guess. try printing blank white pages and see if they come out dirty
Nov 26, 2013 | Xerox WorkCentre Pro 555 Plain Paper Laser...
How to set original to adf
Check the document feeder is it aligned properly. There is a small magnet and sensor magnet on the Document feeder right front sensor under the plastic that side ensure they are aligned. Does happen when you make copies?
Mar 16, 2013 | Minolta FAX2900 Plain Paper Laser
Making a black line on copies top to bottom right in the middle
maybe your scanning glass have a dirt! try to open the document feeder and clean it! or it possible that the problem was coming from the cartridge.. =)
May 17, 2010 | Ricoh Aficio 1515F Plain Paper Laser Fax
WHITE LINES ON FAXES SENT
You have white out or some other white substance blocking your scanner optics. I am assuming this is a thin blank line. What you need to do is make a copy of a document with your machine. You should see the very same blank line on your copy that your customer is seeing on their received fax. Now take this copy and place it in the document feeder the same way you placed the document when you made your copy. Now imagine this document going thru the feeder. The strip that is blank will "match up" with the white out or whatever is causing the blank line. You just need to open up the feeder section where the documents go in to be scanned and look for the thin strip of glass that runs from one side to the other. Using the copy you made with the blank line, use it to see exactly where the glass should have something stuck to it and clean it off with a soft clotch with a little glass cleaner on it. Go ahead and clean the while glass while you are in there. Once clean you can close it back up and run another copy to insure that all the lines are gone.
Good Luck and Thank You for using Fixya.
May 12, 2010 | Canon L220 Plain Paper Laser Fax
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
54 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
