Question about Brother HL-2040 Laser Printer
Line on left side
My printer leaves a straight line all the way down the left margin. Any idea what to do about is?
  • 138 Answers
Try removing the drum and cleaning the corona wire in the drum cartrige. Once the drum unit is removed look at the front right corner for a blue peice. Slide this peice back and forth over the slot 3 or 4 times. When finished move it back all the way right until it "clicks" back into home position. Install the drum back into the machine and try printing a page again.
You can also remove the toner cartridge from the drum and look at the drum for signs of scoring (lines) on the drum.
If that doesn't solve the issue, look under my user name for a "tips and tricks "article that will address the common issues with the Brother supplies.
Hope this helps you. If so rate me with a FIXYA. I'm just a tech trying to help out people in my spare time.
Posted on Aug 30, 2008
My printer is leaving toner "tire marks" up and down the right and left side of the page margin as well as spilling uneven blotches of toner along the right side of the paper.
Your printer needs cleaning. Consult your printer manual on how to clean it. If you do not have the manual, you can usually download it from the printer manufacturer's website.
Apr 23, 2010 | Dell 1700n Laser Printer
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Light print and leaves a blank stripe
Try the blue corona wire on top of the drum unit. If it is not right back to the left it will leave a line on every page.
Jan 04, 2009 | Brother HL 5040 Laser Printer
Horizontal lines down left margin
Sounds like it's a transfer belt and not a drum you are refering too. Each toner cartridge mose likely has a drum built into it. If the lines are only in one color it may be that toner that is bad. But most likely it's the transfer belt, often called an ITU (Image Transfer Unit) or ETB (Electrostatic Transfer Belt). They sometimes get contaminated with dust, oils from fingers, etc... and can't be cleaned, would need to be replaced.
Jan 10, 2008 | Lexmark C510 Laser Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Dec 19, 2007 | HP Photosmart 7450 InkJet Printer
Contents alignment on printed/copied paper
I would recommend a good cleaning of the rollers with a damp rag (old t-shirts are great for this). Some canned air to blow out the insides always seems to improve operation.
If this is helpful to you, would you please rate this solution? Thanks!
Oct 16, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
Brother HL-2040 Laser Printer Logo
139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
