Question about Canon imageRUNNER 2200
Printing crooked from one drawer, and no option to print from another drawer
I'm trying to make 1-->2 sided copies, as I do every week at this time, and the copier is printing horribly crooked from the bottom drawer, and won't let me print from any other drawer but that one when I do 1-->2 sided copies.
I have discovered from experimenting with it that for some reason, when I make 1-1 copies from the glass plate, it wants to take in letter sized paper through the envelope tray on the side of the copier, and it prints correctly when it does this (although I have no clue why it's taking regular paper through the envelope tray...)
I've been through all of the options I can find...and I can't get it to change what it's doing...also, my option for a sample set has disappeared.
I'm completely stumped, and I have to get these copies made....I've wasted so much paper trying to figure out what's wrong!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Posted on Aug 29, 2008
Printing copies crooked
prints ok from a different tray????????????????????
Feb 14, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
Crooked printing
This printer is faulty, I suggest you return it to the supplier to get it repaired or replaced under warranty.
If you try to fix it yourself you could void your warranty.
Sep 01, 2012 | Epson Office Equipment & Supplies
My printer in printing crooked when i print a lot of papers how do i fix that. It works just fine when i print 2 or 3
first determine if its the paper feed by printing several copies off the glass not using the document feeder. If they are crooked coming from there check the paper cassette and make sure the side quides are snug against the stack. That is the usual problem.
Feb 14, 2011 | Brother MFC9440cn AllInOne Laser Printer
How can double sided print
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=ca&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1161389
Jan 15, 2011 | HP LaserJet 3055 All-In-One Printer
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
Ricoh ap610n prints crooked. It's about 4 years old. Has been a great work horse but now prints come out crooked.
99% of the time its paper loaded with the side guides of th paper drawer open too wide. -Carl
May 13, 2010 | Ricoh Aficio AP610N Laser Printer
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
Jan 06, 2009 | Office Equipment & Supplies
Canon imageRUNNER 2200 Logo
330 people viewed this question
old marine
old marine
