COPY HAS AN I/8 INCH BLACK STREAK DOWN ON SIDE
    Problem Solver:
  • 3 Answers
Not sure what make or model.... is the charger cleaning handle pushed all of the way in??
Posted on Aug 29, 2008
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
Logical!
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Large Black streak on outbound fax/copy
1 or 2 LEDs are burned out in the scanner unit.
Sep 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Copies have a white streak near right side of copy canonpc920
PULL OUT THE CARTRIDGE AND SHAKE IT, IF THE COPY IMPROVES ITS OUT OF TONERAND NEEDS REPLACED
Apr 07, 2009 | Canon PC-920 Black and White Copier
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Large black streak down the back of the paper
This is a fairly common problem. More common when you use junk cartridges from printcountry.com.
1) you will need some cotton swabs, isopropyl alcohol and "canned air" or any pressurized computer cleaner.
2) lift up the top console while the unit is on and wait for the cartridges to reset to the center position.
3)Release the grey lock on the LH side of the cartridges and remove cartridges.
4) take alcohol soaked swabs and clean bottom of ports and nozzles.
5) blow out with air.
6) go into program and run clean and align programs. (if you don't have them go to google and type canon mp830 support)
7) retest.
8) if this doesn't work, give to someone you hate or throw out window.
Aug 19, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
143 people viewed this question
k24674
jasbo
jasbo
