Question about Weber Genesis Silver B Grill
Ignition Since I changed the gas tank I at first had some minor problems getting ignition to fire and for the first time had to use a match now even that won't ignite grill- I read a "check regulator" suggestion , how does one do that or does it need to be serviced ?
  • 1 more comment
  • Fred2646 Aug 29, 2008
    I don't hear the gas and no longer see a spark when attempting to inginite the grill (which is only about 2 years old and not often used
    This is my first grill how exactly do you clean the jets ? It sounds like the clog diagnosis may be correct
  • Fred2646 Sep 04, 2008
    Gents-
    I did get it working after cleaning the jets and I found I needed to tighten the plastic screw that attatches to the gas tank - it may have been that the lack of tightening of that screw was preventing the gas flow. Either way it now works again - thanks to all for the assistance
  • 706 Answers
When you turn the gas valve to High or Ignite position..do you hear or smell gas going into the gas burner? If yes, then look at the position of the igniter in respect to the gas burner to see if it generates a spark either with or without gas running.. .. if you have gas entering the gas burner.. and if you've used the Grill a lot.. the jets may be clogged and need cleaned to allow gas flow thru them.. if the jets from the burner are clogged in or near the igniter..it may not ignite easily untill you get lots of propane in the area.. Check the gas jets to make sure you have gas coming out and then check the igniter to make sure it generates a spark.. Hope that helps..
Posted on Aug 29, 2008
  • Rick Gelin
    Rick Gelin Aug 29, 2008
    To be honest, I do not know this particular grill in detail but if it is similar to others..you would first remove the grilling trays that you cook food on, then a lot of mfrs use a shield to cover the burners themselves and protect them from grease droppings etc.. You would have to lift that off and the gas logs should be situated underneath all that.. Many gas burners are only just 'nested' there and can be removed by lifting them up and out.. It should be fairly obvious once you see them beneath the heat shield.. Also.. the ends of these burners attach to the gas feed coming from the shut off valve so you may want to make sure they haven't been dislocated from these gas lines.. If that were the case, then the gas coming from the valve would be dispursed everywhere and not thru the burners ..which in turn would make those burners difficult to ignite... The burner jets themselves are merely holes to allow gas flow.. an d you can clean them with a sharp object that is sized to fit the hole.. I've used drill bits or whatever was handy at that time.. a wire brush can also be used to remove any scaling or rust.. Hope that gets you going...
  • Rick Gelin
    Rick Gelin Sep 04, 2008
    Glad you got it going !
    Regards
2005 Prowler runs good for about 20 minutes then back fires and dies, changed spark plug, replaced coil drained gas tank and replaced feul pump, any suggestions?
problem component in the ignition control module overheating and switching the module off
the backfire is an in appropriate spark time from a problem control module
Sep 29, 2016 | Cars & Trucks
Saturn died while driving and now won't turn over
check to see if the cam shaft is turning while cranking the engine (broken timing belt) run fault codes to find faulty sensors.
Dec 23, 2013 | 2001 Saturn L-Series
I,m unable to start the grill. new gas bottle, every thing attached. It seems like there is no gas flow as I can't even start with a match. Can the gs regulator get stuck so there is no flow?
Hi ircatlin...
ONLY TO THE FOLLOWING IN AN OPEN AREA AWAY FROM FLAMES/FIRE/IGNITION SOURCES.
To answer your question if the gas regulator can get stuck...the answer is YES.
Check to make sure gas is getting thru the regulator...to do this disconnect the hose going to the burner controls...turn on the gas at the tank and listen and smell for gas coming out...if there is no gas coming out, you can sometimes tap lightly the gas regulator and it will free the sticking valve inside and let the gas flow...if the tapping does not work, the replace your regulator as it is faulty.
Please take time to rate me
Sep 03, 2011 | Weber Summit Platinum D4 Grill
Just changed gas bottle, for our gas fire, now cannot get to ignite
When you open the gas line to change the tank you let air in the line very common problem just take the line loose at the gas fire and bleed the air out. If it has auto ignition just let it cycle it will bleed out the air after a few try's.
hope this helps.........
Dec 07, 2010 | Heating & Cooling
Code 1F
"IF" or" Ignition failure", simply means you heater didn't fire. Be sure your gas is on,and if on propane be sure there is at least 30% in the tank (and the valve is open).Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Oct 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
1999 S10 will crank over but will not start.
Check the air gap on the crank shaft sensor, if it does not have a .50 gap it will not send signal to fire coil pack repy to this post if you need more help.
Aug 30, 2009 | 1992 Chevrolet K1500
1995 TOYOTA CORROLLA WOULD NOT FIRE
you are doing something wrong ,but you cant see it and it will confuse you ,call a mobile mechanic out for another opinion ,this fault could be anything and no doubt its something stupid as this car is too old to have a lot of fancy electrics and factory immobiliser,but 95??hmmm could be problem as it was about this time they were fitted .best of british with it and call a mobile mechanic to have a look
Jan 18, 2009 | 1995 Toyota Corolla
2002 s10 not firing
yea run wire to toggel from alt to bat direct feed and change coil
Jan 05, 2009 | 1998 Chevrolet S-10 Pickup
98 dakota engine dies
timing chains either go out or not go out, there is no such thing as an intermittent problem with a timing chain, what about the ignition module? it is sensitive to heat, and like the crank and cam sensors can cause your kind of problem. U did not mention fuel pressure either, electric fuel pumps can stop from heat when they get near the end of there service life (100,000), this is even more common if the fuel tank is run below 1/4 tank allot, this overheats the pump in the tank because it is not covered in gas, that is how it is cooled.
Dec 27, 2008 | Dodge Caravan Cars & Trucks
Weber Genesis Silver B Grill Logo
520 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
