Computers & Internet Logo
Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the instruction on how to replace my LCD Screen on my Inspirion 1501 laptop
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
  • Posted on Aug 28, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2066150
Points
15105
If you go to the dell website and select manuals they often have the service manuals for download from there site.
Robert
1helpful
I lost my BIOS Password on my Laptop it is DELL inspirion 1501 please help ..mike
Check it.
http://home.eunet.no/~pnordahl/ntpasswd/
Download the cd iso and burn it to a cd using your favorite program.
Insert the CD into the drive and boot your computer. You will then be brought to a screen in which you will be asked to download the drivers, select your partition, select you username, and change the password.
Hope this helps
I have a cracked screet with my my dell inspirion 1501 when i try to set it up with a dell flat screen monitor it flickers but does not recognize it and does not work.
go to your computer control panel & chec your resolutions pixels, or your hardware and sound to ajust your mobility setting.
Dell inspirion 1545 screen looks to be cracked internally ,lines going across the screen,can jusy see lines of different colours
instructions for replacing the LCD are here:
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1109848
You can buy a replacement LCD here
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=1545+LCD&_sacat=See-All-Categories
1helpful
Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
No display
The LCD backlight is most likely faulty. If you look at the LCD screen to one side you could see a slight video image, provided the video card is working. To check if the video card is working connect the laptop's video output connector to an external monitor and then boot up your laptop. If you get an image on the monitor, then the problem is with the laptop's LCD display.
As I stated it could be the backlight or a faulty invertot that powers the backlight or it could be the cable/s that connects the LCD to the motherboard.
Try reseating these cables (requires dismantling the laptop).
If this doesn't work then you have a faulty LCD and needs to be replaced. Alternately if cost is too expensive, just use the laptop with an external monitor.
Screen is dark
Hi Yacob
First Run a diags on the dell laptop. You can initiate it by pressing fn+power button together and start the laptop. It will go to the diags screen. Tell me if the diags pass or not and then we will troubleshoot further.
Thank you
Rakesh
Dell Laptop Expert
I need to do a PC restore on my Dell Inspirion 1501. How do I do this? I was told to shut down and when the computer comes on, hold down ctrl and click F11. There is nothing for a PC Restore other than...
Do you have Dell Recovery Disk?, they usually come when you buy the laptop.
If you do:
Inset Disk 1 into the drive and Restart your computer.
Follow the on-screen instructions and you will be asked to insert Disk 2. Do so and wait till everything has finished installing.
If you don't have the Recovery Disk then you need to get them from the Dell.com site.
Please Rate. Thanks
Grand Canyon Tech
Grand Canyon Tech
