Question about E-Machines eMachines Desktop PC
T5026 crashed ... i think.. no cds
I moved my tower to another room, set it up, put in my password and the screen was stuck there. I restarted the computer and it starting making a clicking noise and then the screen said no hard drive found. Now it asks for a boot disk but I can't find any of my cds. Am I out of luck? How can this happen. I was just using the computer fine before I moved it to another room. What can I do?
  • 6 more comments
  • dmetria Aug 28, 2008
    Bunnydawg, I don't know what kind of drive. I'd say whatever is standard in the Emachine. Sorry I wasn't more helpful. I looked on the tower but didn't see anything.
    ok, I will check all plugs. It comes on and the "e" comes on the screen and then it goes to the black screen with the error messages and message to insert boot disk. I'll try again and update in a few. Thanks for your help. As luck would have it, my warranty expired March 18, 2008.
    Naw, didn't work. Still says "no bootable device. Insert boot disk and press any key". Any other thoughts? Oh, it was making a clicking noise before. I didn't hear it this time.
    yes, if I press F2. what do i look for
  • dmetria Aug 29, 2008
    Robert, I'm am so appreciative of the time you are spending to help me. Okay, I found the screen (I think) and for Primary Master it says TSSTcorpCD/DVDW-ATAPI and for Primary Slave it says GCR-8483B-ATAPI.
    Use Automatice Mode is set to
    I did see that Max CPUID value limit is set to disable. The sidebar says "this should be enabled in order to boot legacy OSes that cannot support CPUs with extended CPUID functions. Should I switch that to
  • Roberta Smith
    Roberta Smith May 11, 2010
    the drive may have failed.... are you able to get into the bios to see if the drive is detected ?
    Robert
  • Roberta Smith
    recheck all the items plugged into the computer to make sure they are connected properly. i presume it stops before you can try booting to safe mode ?
  • Roberta Smith
    there are alot of reasons a hard disk will fail. is it a maxtor drive by chance ?
    Robert
    Brigadier General:
  • 5,158 Answers
The first entry.... where you can set the time but also detect the hard drive.... make sure it is set to auto detect.... also is the drive shown as master or slave and it will tell you the brand and model number if it detects it.
half way to a solution if it is detected properly
Robert
Posted on Aug 29, 2008
Lost Windows7 Home Premium. recieved system recovery CDs (there are 5). after files load goes to language setup screen. pick language then exit is only option it will allow. says to press F2 to enter bios...
It appears that BIOS password it set on your computer, if you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps:
Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 29, 2010 | Computers & Internet
Trying to begin
You have to clear the CMOS to clear all power on passwords.
With the computer facing you remove the power cord and then take of the left hand side panel of the tower to expose the motherboard.
Look near the bottom right of the motherboard for the BIOS battery. It looks like this >>>>>
Remove this battery for about 20 minutes periodically hitting the on/off switch to dispel any residual power from the motherboard. This will clear the CMOS for you.
After 20 mins is up put the battery back in and put the side panel back on.
Turn on the computer and it should boot to the operating system.
Remember to set the year, date and time as these will be reset.
Regards.
Jul 09, 2010 | Dell Dimension 9100 PC Desktop
My pc frequently restarting anytime
It may be possible that your CPU is overheating and the BIOS restarts your computer for safety reasons.
You should open the tower and clean the inside of it. Unplug the cooler from the processor, clean the fan od the cooler, install new cooling paste on the processor and put them back.
It should work perfectly.
N.B: Do not change the BIOS settings.
If you need further assistance, leave a comment.
Cheers
Jun 08, 2010 | Intel D865GBF Motherboard
Zen player mosaic crashes re-building library (uses flash memory)
I've been having the exact same problem. No matter how often I reset it it still becomes stuck on the rebuilding screen. I was thinking I may just copy all of my music onto my computer and then do a complete reset on my Zen and copy it back but I don't want to go to all that trouble if there is an easier way to fix it.
Jan 25, 2010 | Creative Labs Creative Technology Zen MP3...
Computer stuck on black screen from crashing
Make sure that your hard drive is set as first boot device and disconnect all the USB devices from the system and than try to boot.
Apr 21, 2009 | Computers & Internet
Tower is beeping and monitor on/off switch is blinking
If the computer has been moved recently, I would chack the Video card in the mother board to make sure it is seated in the slot all the, Unless you have on board video.
Apr 12, 2009 | Dell Inspiron 531s Desktop Computer
I ran the recovery CDs/Administrators password
Go to http://www.ubcd4win.com/index.htm to download UBCD4Win. UBCD4Win will allow you to creat a bootable disc with your Windows disc that will have the Windows environment and tools to recover passwords among other things. Read the instructions carefully.
Post back with questions.
Dec 29, 2008 | Gateway GT5404 PC Desktop
When you walk in front of my pc desktop tower it restarts and a black screen comes up and you have to reboot the computer to get it to start windows
wow, what is that,,, a new one definitely. um how about checking the cables and making sure they are securely plugged in..
then maybe if possible move the tower to a different place of the room and see what happens :)
strange one
Dec 21, 2008 | Computers & Internet
E-machines T5026 comes on goes only to the "e" screen
Some bios use F5 for a one time boot sequence. If lucky you'll get this option to choose cd rom as first boot device.
You can remove the Cmos battery for about 3 min. It is the small round watch looking type battery on the motherboard. This may reset all defaults in case of hardware/software conflicts.
If nothing still try a new Hard Drive.
YES I would say you have crashed because it is "just stuck". But this doesn't mean your computer is fried.
Try these things if your want let me know what happens and I'll try to help from there.
There is a recovery option with the xp installation disk that will fix your master boot and boot record on Hard Drive. If your interested let me know!
Jun 29, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
