Question about ASUS Computers & Internet
I have an A8N-SLI motherboard that has just go no, no, nothing, checked the power source and changed it out , nothing. I like this board and cpu. where can I get a check on the board?????
I did as you said
. turned the battery over for 30 sec. worked cp. started up. thanks
Posted on Aug 29, 2008
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Asus A8N-Sli
Hi
Hi the plate which holds the CPU will be prsent on the motherboard itself, the only other plate is the one i described above
I hope this helps
Mar 04, 2010 | ASUS A8N-SLI Motherboard
Does ASUS A8N-SLI DELUXE support fan speed changing?
You can research *********** board and drivers at ASUS.com.
You may find a new BIOS update which controls the fan speeds and temp.
If not, you can find plenty of frreware which will handle *********** board.
Nov 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Coolmaster cm690 asus a8n-sli deluxe
the boards today have real fine typeset near the connection pins but they are there
Jul 31, 2009 | ASUS A8N-SLI Deluxe Motherboard
A8N Sli motherboards graphic card and CPU capatibilies
Hi!
Nop, it takes only AMD
The infosite about that MB is still up, you will find it here:
http://uk.asus.com/search.aspx?searchitem=1&searchkey=A8N-SLI
There you will find all the info you want. BTW, its not only the MB's size if the nvidia card fits or not, its the size of the case to.
Good luck
Nic
Apr 07, 2009 | ASUS A8N-SLI Motherboard
Is my CPU fried
IF *********** BOARD IT FRIED DOESN'T MEAN UR CPU IS IF YOU CPU IS INTEL MOST LIKELY YOUR CPU IS FINE IF AMD THEIRS A 40% CHANCE IT IS FRIED - I WORK WITH COMPUTERS AND IVE SEEN IT ALL BEFORE SO I KNOW WHAT IM TALKING ABOUT
Jun 30, 2008 | ASUS A8N-VM Motherboard
System wouldn't Boot
If your CPU or memory were an issue your Asus board would sound off with BIOS beeps. Asus uses the Award BIOS & you can see what these beeps mean at the link below. Regaurding your PC not able to boot is an issue with your PCIE/PEG video card-in relationship with BIOS setting & the SLI switch card mode that came with your board. When running 1PEG video card you must set this in the BIOS to Auto & you need your SLI switch card connected in its slot. By default, the EZ Selector card is set for a single graphic card. When you install dual PCIE graphic cards on A8N-SLI series motherboards, please make sure EZ Selector card set to the Dual Video Card side and properly inserted. Link to Award Bios beep codes: http://www.bioscentral.com/beepcodes/awardbeep.htm
Will come in handy.
Reading the FAQ's at Asus site will help you better understand your A8N-SLI Deluxe. You'll need to fill in the, "Please Select the Product" first: http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Dec 05, 2007 | ASUS A8N-SLI Deluxe Motherboard
Computers & Internet Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
