Question about Canon PIXMA MP150 All-In-One InkJet Printer
Reset ink level on CANON MP 140 PIXMA PRINTER
When installing refill cartridges the ink level still shows empty on the computer ink level status manager. I tried to unplug the printer for a couple of minutes after installing the refill cartridges but to no avail. What can I do to fix this? The printer does print with these cartridges but the quality on the ink printing looks to be not all that good.
Thanks
  • 11 more comments
  • erubiox Sep 04, 2008
    Y have problem to change the cartridges of my printer MP140. Y have an alam, that the cartridges are still empty
  • pinksocks83 Sep 04, 2008
    just added new ink, the alarm light is lit up and flashing E3?
  • andreialex26 Oct 16, 2008
    nu mai raspunde la comenzi se aprind ledurile a si c si-mi da eroare
  • nrml_katariy Nov 14, 2008
    yes i have the same problem
  • Anonymous Dec 03, 2008
    My canon Pixma 145.
    I tried reseting the ink but unsuccessful. Can anyone please help?
  • Anonymous Dec 11, 2008
    gggg
  • Anto_Giscard Jan 04, 2009
    When I give a print, the message I get is "the following ink catridge cannot be recogonised" and list the Black and Color. Printing cannot be completed because the ink catridge may not be installed properly or maynot be compatible with this printer
  • arun_ec Jan 11, 2009
    my problem is E 5 due to low ink level please solve this problem
    thanks
  • Biom Jan 13, 2009
    It worked for me. My Mp140 reseted well.
  • nt4r Feb 06, 2009
    Thank You very...very much for this share information
    Now my printer not in low ink again
    DDot
  • al1 Apr 14, 2009
    Thank you. i ve been searching for days before Maynard solution. Only difference : i pressed RESET instead of COLOR to have the page printed. Thanks once more from France
  • app_3rp11170
    app_3rp11170 Oct 27, 2012
    Wonderfull trick... I have tried 2x and it works... Very very much thank's for your amazing trick....
  • Anonymous Mar 14, 2014
    I refill B40 cartridge and C41 empty I want to take print out but printing not completed, and windows show ink cannot recognised.
  • 4 Answers
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
  • 6 more comments
  • gastomaster Sep 13, 2010
    Thanks, it really helped, now the ink levels on the indicator from the Canon Utility are actually showing the ink levels at their top.
  • seafahre Oct 01, 2010
    It does not show the #0 on mine. It flashes only the yellow tryangle!
  • mast3rf0x Oct 12, 2010
    After a lot of try, I can't manage the error. But I've discovered a variety of Service Menu on the Canon Pixma Mp140. You can found it here.
  • chris monaghan Oct 23, 2010
    yea same with mine how do i fix this
  • Naveen Roy Jul 09, 2012
    Wow, gotta really thank you for this one! Worked perfectly and now the ink levels are all up!! Awesome stuff...
  • app_3rp11170
  • Anirban08 Jul 24, 2013
    thank you so much... its work perfect.. lot of money saved,,... :)
  • Biplab Roy
    Biplab Roy Jun 01, 2014
    Thanks a million ton sir. Your solution is still helpful after more than 5 years. I shall buy you a beer when we meet.
Refilled cartridges are monitored as used cartridges .the mp 140 such as all printers ,accept inks oem like a serial number.
when you place the ink back in though it maybe refilled,the chip inside the printer,remembers that this cartridge has been used already,no matter if its empty or not. the only thing you can do to solve this problem is deactivating the monitored levels of ink,by pressing and holding cancel button for about 15 seconds or so
Posted on Sep 09, 2008
  • 6 Answers
All you have to do is reset your printer after a recharge. To do this just hold the red button after you start your printer somth like 10-15 sec. The printer will show you thet yoour ink level is low but will work fine
Posted on Oct 09, 2009
Tried a few methods for my MP140, but only 1, maynard`s worked, a big thanks
great Post
Posted on Dec 22, 2009
  • rollih Dec 22, 2009
    maynards was the only method worked for my MP140
    a big thank you
    good post
    Problem Solver:
  • 5 Answers
Maynard solution works fine. i translated it into french for french customers and had many "ok" answers.
Posted on Dec 09, 2009
My printer canon mp140 only cost me £40.00 it looks like i am going to have to spend the same amount again on ink any ideas on doing it cheaper as i have 4 kids who love using my printer for homework sheets etc many thanks diane
    Welcome Back:
    Visited the website for 2 consecutive days.
Best SolutionMy problem is Canon MP145 Inks Alarm and work fine now.
Thanks a lot and this helpful for me.
Success.........
Great Post.......
Posted on Dec 03, 2009
    New Friend:
Just press & hold the RESET button for 10 seconds after the power led is stable ON (not blinking).
1. Power on the Printer.
2. Wait till the PWR led is STABLE GREEN (not blinking)
3. Press & hold the RESET button for 10 seconds.
4. You should see number 1 in the display.
5. You can proceed with the scanner now. Issue is solved.
Posted on Oct 13, 2014
    New Friend:
I had same problem. color cartridge not recognising. I tried your method but after pressing the rest button twice I don't get the 0 value instead alarm flash.
Posted on Oct 12, 2014
  • Biplab Roy
    Biplab Roy Oct 13, 2014
    Just press & hold the RESET button for 10 seconds after the power led is stable ON (not blinking). 1. Power on the Printer. 2. Wait till the PWR led is STABLE GREEN (not blinking) 3. Press & hold the RESET button for 10 seconds. 4. You should see number 1 in the display. 5. You can proceed with the scanner now. Issue is solved.
  • 4 Answers
This solution worked for me too, I found the solution from this site How to reset Canon mp140. It was quick and easy, I know inks are so expensive that we need to refill them to save some dollars. :)
Posted on Aug 16, 2012
Maynard's solution worked for my MP140.
Thank you !
John
Javea, Spain
Posted on Apr 13, 2010
Wonderfull! Maynard's solution worked fine for my MP140!
Thank you so much!
Posted on Mar 15, 2010
SOURCE:
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ca i recharge catridge form cnon pixma MX 330?, i
All catridges are made to show the ink levels only for 1st use, once you refill the cartridge you need to reset the ink level chip, some cartrides level cannot be reset, some can be re-set.
There are solution available for some specific printer ink cartridges on how to re-set the ink level.
You can google and loacte the solution giving cartridge number in the search field of google.
Dec 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I cannot get printer to recognize new or refilled cartridges. How do I reset Cannon MX310 to see new cartridges?
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
If you put a new cartridges the printer will recognize it automatically.
Oct 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E5 problem
E5, says the ink cartridges are the wrong type, not properly installed, or not installed at all. You can't refill those without replacing the chip or resetting the chip. Many refilled cartridges just don't work...
Aug 27, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
55,824 people viewed this question
Clive
Clive
old marine
old marine
